DEV: Tests can reset a single registry (#13618)
Plugins can use this method to reset their specific registries without touching the ones defined in core.
diff --git a/lib/discourse_plugin_registry.rb b/lib/discourse_plugin_registry.rb
index 840b038..097db83 100644
--- a/lib/discourse_plugin_registry.rb
+++ b/lib/discourse_plugin_registry.rb
@@ -227,4 +227,11 @@ class DiscoursePluginRegistry
+  def self.reset_register!(register_name)
+    found_register = @@register_names.detect { |name| name == register_name }
+    if found_register
+      instance_variable_set(:"@#{found_register}", nil)
+    end
+  end
GitHub sha: 6be956339cba656700f18ff4729f42c9fb5b1b4c
This commit appears in #13618 which was approved by davidtaylorhq. It was merged by romanrizzi.
