DEV: Topic tracking state improvements (PR #13218)
Original PR which had to be reverted https://github.com/discourse/discourse/pull/12555. See the description there for what this PR is achieving, plus below.
The issue with the original PR is addressed in DEV: Topic tracking state improvements by martin-brennan · Pull Request #12958 · discourse/discourse · GitHub
If you went to the x unread link for a tag Chrome would freeze up and possibly crash, or eventually unfreeze after nearly 10 mins. Other routes for unread/new were similarly slow. From profiling the issue was the sync function of topic-tracking-state.js, which calls down to isNew which in turn calls moment, a change I had made in the PR above. The time it takes locally with ~1400 topics in the tracking state is 2.3 seconds.
To solve this issue, I have moved these calculations for “created in new period” and “unread not too old” into the tracking state serializer.
When I was looking at the profiler I also noticed this issue which was just compounding the problem. Every time we modify topic tracking state we recalculate the sidebar tracking/everything/tag counts. However this calls forEachTracked and countTags which can be quite expensive as they go through the whole tracking state (and were also calling the removed moment functions).
I added some logs and this was being called 30 times when navigating to a new /unread route because sync is being called from build-topic-route (one for each topic loaded due to pagination). So I just added a debounce here and it makes things even faster.
Finally, I changed topic tracking state to use a Map so our counts of the state keys is faster (Maps have .size whereas objects you have to do Object.keys(obj) which is O(n).)
GitHub
The title of this pull request changed from “DEV: Topic tracking state improvements (#12958)” to "DEV: Topic tracking state improvements
This is an aesthetic comment, but do you find bind(this) more readable, than, say:
this.topicTrackingState.onStateChange(() => this._updateTrackingTopics())
agreed, fixed
