DEV: TopicTrackingState calls should happen in the background (#11682)
- DEV: TopicTrackingState calls should happen in the background
It was observed that calling TopicTrackingState on popular topics could result in a large number of calls to redis, resulting in slow response times when posting replies.
These calls should be moved to a background job.
- DEV: PostUpdateTopicTrackingState should execute on default queue
diff --git a/app/jobs/regular/post_update_topic_tracking_state.rb b/app/jobs/regular/post_update_topic_tracking_state.rb
new file mode 100644
index 0000000..c68a67b
--- /dev/null
+++ b/app/jobs/regular/post_update_topic_tracking_state.rb
@@ -0,0 +1,20 @@
+module Jobs
+ class PostUpdateTopicTrackingState < ::Jobs::Base
+ def execute(args)
+ post = Post.find_by(id: args[:post_id])
+ if post
+ TopicTrackingState.publish_unmuted(post.topic)
+ if post.post_number > 1
+ TopicTrackingState.publish_muted(post.topic)
+ TopicTrackingState.publish_unread(post)
+ end
+ TopicTrackingState.publish_latest(post.topic, post.whisper?)
+ end
+ end
+ end
+end
diff --git a/lib/post_jobs_enqueuer.rb b/lib/post_jobs_enqueuer.rb
index cd80eaa..1fbbe01 100644
--- a/lib/post_jobs_enqueuer.rb
+++ b/lib/post_jobs_enqueuer.rb
@@ -57,12 +57,7 @@ class PostJobsEnqueuer
def after_post_create
- TopicTrackingState.publish_unmuted(@post.topic)
- if @post.post_number > 1
- TopicTrackingState.publish_muted(@post.topic)
- TopicTrackingState.publish_unread(@post)
- end
- TopicTrackingState.publish_latest(@topic, @post.whisper?)
+ Jobs.enqueue(:post_update_topic_tracking_state, post_id: @post.id)
Jobs.enqueue_in(SiteSetting.email_time_window_mins.minutes,
:notify_mailing_list_subscribers,
diff --git a/spec/components/post_creator_spec.rb b/spec/components/post_creator_spec.rb
index 310ba1a..536015b 100644
--- a/spec/components/post_creator_spec.rb
+++ b/spec/components/post_creator_spec.rb
@@ -128,8 +128,13 @@ describe PostCreator do
expect(channels.find { |s| s =~ /new/ }).to eq(nil)
- it "generates the correct messages for a secure topic" do
+ it 'enqueues job to generate messages' do
+ p = creator.create
+ expect(job_enqueued?(job: :post_update_topic_tracking_state, args: { post_id: p.id })).to eq(true)
+ end
+ it "generates the correct messages for a secure topic" do
+ Jobs.run_immediately!
UserActionManager.enable
admin = Fabricate(:admin)
@@ -169,7 +174,7 @@ describe PostCreator do
it 'generates the correct messages for a normal topic' do
p = nil
GitHub sha: b1f32f2f
