DEV: track the correct channel in specs
These tests are erratically failing due to distributed cache messages that can land between tests
Ensure we are only looking for the correct messages
diff --git a/plugins/poll/spec/lib/polls_updater_spec.rb b/plugins/poll/spec/lib/polls_updater_spec.rb
index 871fc94..2a103d1 100644
--- a/plugins/poll/spec/lib/polls_updater_spec.rb
+++ b/plugins/poll/spec/lib/polls_updater_spec.rb
@@ -54,7 +54,7 @@ describe DiscoursePoll::PollsUpdater do
   describe "update" do
     it "does nothing when there are no changes" do
-      message = MessageBus.track_publish do
+      message = MessageBus.track_publish("/polls/#{post.topic_id}") do
         update(post, polls)
       end.first
@@ -109,7 +109,7 @@ describe DiscoursePoll::PollsUpdater do
         expect(Poll.find_by(post: post)).to_not be
           update(post, polls)
         end.first
@@ -135,7 +135,7 @@ describe DiscoursePoll::PollsUpdater do
           freeze_time 1.month.from_now
             update(post, polls_with_some_attributes)
           end.first
@@ -166,7 +166,7 @@ describe DiscoursePoll::PollsUpdater do
         describe "inside the edit window" do
           it "and deletes the votes" do
             end.first
GitHub sha: 3c1fa391
