DEV: trash category definition topic instead of destroying. (#14356)
After deleting a category, we should soft-delete the category definition topic instead of hard deleting it. Else it causes issues while doing the user merge action if the source user has an orphan post that belongs to the deleted topic.
diff --git a/app/models/category.rb b/app/models/category.rb
index d36d490..07b890e 100644
--- a/app/models/category.rb
+++ b/app/models/category.rb
@@ -25,7 +25,7 @@ class Category < ActiveRecord::Base
   register_custom_field_type(REQUIRE_REPLY_APPROVAL, :boolean)
   register_custom_field_type(NUM_AUTO_BUMP_DAILY, :integer)
-  belongs_to :topic, dependent: :destroy
+  belongs_to :topic
   belongs_to :topic_only_relative_url,
               -> { select "id, title, slug" },
               class_name: "Topic",
@@ -67,6 +67,7 @@ class Category < ActiveRecord::Base
   validates :slug, exclusion: { in: RESERVED_SLUGS }
   after_create :create_category_definition
+  after_destroy :trash_category_definition
   before_save :apply_permissions
   before_save :downcase_email
@@ -296,6 +297,10 @@ class Category < ActiveRecord::Base
+  def trash_category_definition
+    self.topic&.trash!
+  end
   def topic_url
     if has_attribute?("topic_slug")
       Topic.relative_url(topic_id, read_attribute(:topic_slug))
diff --git a/spec/models/category_spec.rb b/spec/models/category_spec.rb
index 63c3849..8668da4 100644
--- a/spec/models/category_spec.rb
+++ b/spec/models/category_spec.rb
@@ -538,7 +538,7 @@ describe Category do
     it 'is deleted correctly' do
       @category.destroy
       expect(Category.exists?(id: @category_id)).to be false
-      expect(Topic.exists?(id: @topic_id)).to be false
+      expect(Topic.with_deleted.where.not(deleted_at: nil).exists?(id: @topic_id)).to be true
       expect(SiteSetting.shared_drafts_category).to be_blank
GitHub sha: a8b2e7e343d9b56564bf7a9189d15006dee24a8c
This commit appears in #14356 which was approved by eviltrout and tgxworld. It was merged by vinothkannans.
