DEV: Update `bin/bundle` (#13067)
DEV: Update bin/bundle (#13067)
This fixes the following error I’ve been seeing lately in RubyMine:
Error:Your bin/bundle was not generated by Bundler, so this binstub cannot run. Replace bin/bundle by running bundle binstubs bundler --force, then run this command again.
diff --git a/bin/bundle b/bin/bundle
index 58115ec..a71368e 100755
--- a/bin/bundle
+++ b/bin/bundle
@@ -1,5 +1,114 @@
 #!/usr/bin/env ruby
 # frozen_string_literal: true
-ENV['BUNDLE_GEMFILE'] ||= File.expand_path('../../Gemfile', __FILE__)
-load Gem.bin_path('bundler', 'bundle')
+# This file was generated by Bundler.
+# The application 'bundle' is installed as part of a gem, and
+# this file is here to facilitate running it.
+require "rubygems"
+m = Module.new do
+  module_function
+  def invoked_as_script?
+    File.expand_path($0) == File.expand_path(__FILE__)
+  end
+  def env_var_version
+    ENV["BUNDLER_VERSION"]
+  end
+  def cli_arg_version
+    return unless invoked_as_script? # don't want to hijack other binstubs
+    return unless "update".start_with?(ARGV.first || " ") # must be running `bundle update`
+    bundler_version = nil
+    update_index = nil
+    ARGV.each_with_index do |a, i|
+      if update_index && update_index.succ == i && a =~ Gem::Version::ANCHORED_VERSION_PATTERN
+        bundler_version = a
+      end
+      next unless a =~ /\A--bundler(?:[= ](#{Gem::Version::VERSION_PATTERN}))?\z/
+      bundler_version = $1
+      update_index = i
+    end
+    bundler_version
+  end
+  def gemfile
+    gemfile = ENV["BUNDLE_GEMFILE"]
+    return gemfile if gemfile && !gemfile.empty?
+    File.expand_path("../../Gemfile", __FILE__)
+  end
+  def lockfile
+    lockfile =
+      case File.basename(gemfile)
+      when "gems.rb" then gemfile.sub(/\.rb$/, gemfile)
+      else "#{gemfile}.lock"
+      end
+    File.expand_path(lockfile)
+  end
+  def lockfile_version
+    return unless File.file?(lockfile)
+    lockfile_contents = File.read(lockfile)
+    return unless lockfile_contents =~ /\n\nBUNDLED WITH\n\s{2,}(#{Gem::Version::VERSION_PATTERN})\n/
+    Regexp.last_match(1)
+  end
+  def bundler_version
+    @bundler_version ||=
+      env_var_version || cli_arg_version ||
+        lockfile_version
+  end
+  def bundler_requirement
+    return "#{Gem::Requirement.default}.a" unless bundler_version
+    bundler_gem_version = Gem::Version.new(bundler_version)
+    requirement = bundler_gem_version.approximate_recommendation
+    return requirement unless Gem::Version.new(Gem::VERSION) < Gem::Version.new("2.7.0")
+    requirement += ".a" if bundler_gem_version.prerelease?
+    requirement
+  end
+  def load_bundler!
+    ENV["BUNDLE_GEMFILE"] ||= gemfile
+    activate_bundler
+  end
+  def activate_bundler
+    gem_error = activation_error_handling do
+      gem "bundler", bundler_requirement
+    end
+    return if gem_error.nil?
+    require_error = activation_error_handling do
+      require "bundler/version"
+    end
+    return if require_error.nil? && Gem::Requirement.new(bundler_requirement).satisfied_by?(Gem::Version.new(Bundler::VERSION))
+    warn "Activating bundler (#{bundler_requirement}) failed:\n#{gem_error.message}\n\nTo install the version of bundler this project requires, run `gem install bundler -v '#{bundler_requirement}'`"
+    exit 42
+  end
+  def activation_error_handling
+    yield
+    nil
+  rescue StandardError, LoadError => e
+    e
+  end
+end
+m.load_bundler!
+if m.invoked_as_script?
+  load Gem.bin_path("bundler", "bundle")
+end
GitHub sha: 4c26dd09
This commit appears in #13067 which was approved by CvX. It was merged by gschlager.
