DEV: update dependencies with vulnerabilities (#63)
diff --git a/assets/docker-manager-app.js b/assets/docker-manager-app.js
index 8352163..491c11d 100644
--- a/assets/docker-manager-app.js
+++ b/assets/docker-manager-app.js
@@ -127,4 +127,4 @@ e.default=t}),define("manager-client/templates/upgrade",["exports"],function(e){
 var t=Ember.HTMLBars.template({id:"H4zT5h6q",block:'{"symbols":[],"statements":[[7,"h3"],[9],[0,"Upgrade "],[1,[21,"title"],false],[10],[0,"\\n\\n"],[1,[27,"progress-bar",null,[["percent"],[[23,["percent"]]]]],false],[0,"\\n\\n"],[4,"if",[[23,["complete"]]],null,{"statements":[[0,"  "],[7,"p"],[9],[0,"Upgrade completed successfully!"],[10],[0,"\\n"]],"parameters":[]},null],[0,"\\n"],[4,"if",[[23,["failed"]]],null,{"statements":[[0,"  "],[7,"p"],[9],[0,"Sorry, there was an error upgrading Discourse. Please check the logs below."],[10],[0,"\\n"]],"parameters":[]},null],[0,"\\n"],[4,"if",[[23,["isUpToDate"]]],null,{"statements":[[4,"unless",[[23,["multiUpgrade"]]],null,{"statements":[[0,"    "],[7,"p"],[9],[1,[21,"title"],false],[0," is at the newest version."],[10],[0,"\\n"]],"parameters":[]},{"statements":[[0,"    "],[7,"p"],[9],[0,"Everything is up-to-date."],[10],[0,"\\n"]],"parameters":[]}]],"parameters":[]},{"statements":[[0,"  "],[7,"div"],[11,"style","clear: both"],[9],[0,"\\n    "],[7,"button"],[12,"disabled",[21,"upgrading"]],[11,"class","btn"],[9],[1,[21,"upgradeButtonText"],false],[3,"action",[[22,0,[]],"start"]],[10],[0,"\\n"],[4,"if",[[23,["upgrading"]]],null,{"statements":[[0,"      "],[7,"button"],[11,"class","btn unlock"],[9],[0,"Reset Upgrade"],[3,"action",[[22,0,[]],"resetUpgrade"]],[10],[0,"\\n"]],"parameters":[]},null],[0,"  "],[10],[0,"\\n"]],"parameters":[]}],[0,"\\n"],[1,[27,"x-console",null,[["output","followOutput"],[[23,["output"]],true]]],false],[0,"\\n"]],"hasEval":false}',meta:{moduleName:"manager-client/templates/upgrade.hbs"}})
 e.default=t}),define("manager-client/config/environment",[],function(){try{var e="manager-client/config/environment",t=document.querySelector('meta[name="'+e+'"]').getAttribute("content"),n={default:JSON.parse(decodeURIComponent(t))}
 return Object.defineProperty(n,"__esModule",{value:!0}),n}catch(r){throw new Error('Could not read config from meta tag with name "'+e+'".')}})
-runningTests||require("manager-client/app").default.create({name:"manager-client",version:"0.0.0+35f9d5c5"})
+runningTests||require("manager-client/app").default.create({name:"manager-client",version:"0.0.0+0807e059"})
diff --git a/assets/docker-manager-vendor.js b/assets/docker-manager-vendor.js
index 7bc1aea..260d4ec 100644
--- a/assets/docker-manager-vendor.js
+++ b/assets/docker-manager-vendor.js
@@ -4677,74 +4677,74 @@ e.title?r.find(".modal-header").prepend(d):d.css("margin-top","-10px").prependTo
 i(e,r,f[n])}),r.on("click",".bootbox-close-button",function(e){i(e,r,f.onEscape)}),r.on("keyup",function(e){27===e.which&&r.trigger("escape.close.bb")}),t(e.container).append(r),r.modal({backdrop:!!e.backdrop&&"static",keyboard:!1,show:!1}),e.show&&r.modal("show"),r},f.setDefaults=function(){var e={}
 2===arguments.length?e[arguments[0]]=arguments[1]:e=arguments[0],t.extend(h,e)},f.hideAll=function(){return t(".bootbox").modal("hide"),f}
 var d={bg_BG:{OK:"Ок",CANCEL:"Отказ",CONFIRM:"Потвърждавам"},br:{OK:"OK",CANCEL:"Cancelar",CONFIRM:"Sim"},cs:{OK:"OK",CANCEL:"Zrušit",CONFIRM:"Potvrdit"},da:{OK:"OK",CANCEL:"Annuller",CONFIRM:"Accepter"},de:{OK:"OK",CANCEL:"Abbrechen",CONFIRM:"Akzeptieren"},el:{OK:"Εντάξει",CANCEL:"Ακύρωση",CONFIRM:"Επιβεβαίωση"},en:{OK:"OK",CANCEL:"Cancel",CONFIRM:"OK"},es:{OK:"OK",CANCEL:"Cancelar",CONFIRM:"Aceptar"},et:{OK:"OK",CANCEL:"Katkesta",CONFIRM:"OK"},fa:{OK:"قبول",CANCEL:"لغو",CONFIRM:"تایید"},fi:{OK:"OK",CANCEL:"Peruuta",CONFIRM:"OK"},fr:{OK:"OK",CANCEL:"Annuler",CONFIRM:"D'accord"},he:{OK:"אישור",CANCEL:"ביטול",CONFIRM:"אישור"},hu:{OK:"OK",CANCEL:"Mégsem",CONFIRM:"Megerősít"},hr:{OK:"OK",CANCEL:"Odustani",CONFIRM:"Potvrdi"},id:{OK:"OK",CANCEL:"Batal",CONFIRM:"OK"},it:{OK:"OK",CANCEL:"Annulla",CONFIRM:"Conferma"},ja:{OK:"OK",CANCEL:"キャンセル",CONFIRM:"確認"},lt:{OK:"Gerai",CANCEL:"Atšaukti",CONFIRM:"Patvirtinti"},lv:{OK:"Labi",CANCEL:"Atcelt",CONFIRM:"Apstiprināt"},nl:{OK:"OK",CANCEL:"Annuleren",CONFIRM:"Accepteren"},no:{OK:"OK",CANCEL:"Avbryt",CONFIRM:"OK"},pl:{OK:"OK",CANCEL:"Anuluj",CONFIRM:"Potwierdź"},pt:{OK:"OK",CANCEL:"Cancelar",CONFIRM:"Confirmar"},ru:{OK:"OK",CANCEL:"Отмена",CONFIRM:"Применить"},sq:{OK:"OK",CANCEL:"Anulo",CONFIRM:"Prano"},sv:{OK:"OK",CANCEL:"Avbryt",CONFIRM:"OK"},th:{OK:"ตกลง",CANCEL:"ยกเลิก",CONFIRM:"ยืนยัน"},tr:{OK:"Tamam",CANCEL:"İptal",CONFIRM:"Onayla"},zh_CN:{OK:"OK",CANCEL:"取消",CONFIRM:"确认"},zh_TW:{OK:"OK",CANCEL:"取消",CONFIRM:"確認"}}
-return f.addLocale=function(e,n){return t.each(["OK","CANCEL","CONFIRM"],function(e,t){if(!n[t])throw new Error("Please supply a translation for '"+t+"'")}),d[e]={OK:n.OK,CANCEL:n.CANCEL,CONFIRM:n.CONFIRM},f},f.removeLocale=function(e){return delete d[e],f},f.setLocale=function(e){return f.setDefaults("locale",e)},f.init=function(n){return e(n||t)},f}),function(e,t){"object"==typeof exports&&"undefined"!=typeof module?module.exports=t(require("jquery")):"function"==typeof define&&define.amd?define(["jquery"],t):e.Util=t(e.jQuery)}(this,function(e){"use strict"
+return f.addLocale=function(e,n){return t.each(["OK","CANCEL","CONFIRM"],function(e,t){if(!n[t])throw new Error("Please supply a translation for '"+t+"'")}),d[e]={OK:n.OK,CANCEL:n.CANCEL,CONFIRM:n.CONFIRM},f},f.removeLocale=function(e){return delete d[e],f},f.setLocale=function(e){return f.setDefaults("locale",e)},f.init=function(n){return e(n||t)},f}),function(e,t){"object"==typeof exports&&"undefined"!=typeof module?module.exports=t(require("jquery")):"function"==typeof define&&define.amd?define(["jquery"],t):(e=e||self).Util=t(e.jQuery)}(this,function(e){"use strict"
 e=e&&e.hasOwnProperty("default")?e.default:e
 var t="transitionend"
 function n(t){var n=this,i=!1
 return e(this).one(r.TRANSITION_END,function(){i=!0}),setTimeout(function(){i||r.triggerTransitionEnd(n)},t),this}var r={TRANSITION_END:"bsTransitionEnd",getUID:function(e){do{e+=~~(1e6*Math.random())}while(document.getElementById(e))
 return e},getSelectorFromElement:function(e){var t=e.getAttribute("data-target")
 if(!t||"#"===t){var n=e.getAttribute("href")
-t=n&&"#"!==n?n.trim():""}return t&&document.querySelector(t)?t:null},getTransitionDurationFromElement:function(t){if(!t)return 0
+t=n&&"#"!==n?n.trim():""}try{return document.querySelector(t)?t:null}catch(r){return null}},getTransitionDurationFromElement:function(t){if(!t)return 0
 var n=e(t).css("transition-duration"),r=e(t).css("transition-delay"),i=parseFloat(n),o=parseFloat(r)
 return i||o?(n=n.split(",")[0],r=r.split(",")[0],1e3*(parseFloat(n)+parseFloat(r))):0},reflow:function(e){return e.offsetHeight},triggerTransitionEnd:function(n){e(n).trigger(t)},supportsTransitionEnd:function(){return Boolean(t)},isElement:function(e){return(e[0]||e).nodeType},typeCheckConfig:function(e,t,n){for(var i in n)if(Object.prototype.hasOwnProperty.call(n,i)){var o=n[i],a=t[i],s=a&&r.isElement(a)?"element":(u=a,{}.toString.call(u).match(/\s([a-z]+)/i)[1].toLowerCase())
 if(!new RegExp(o).test(s))throw new Error(e.toUpperCase()+': Option "'+i+'" provided type "'+s+'" but expected type "'+o+'".')}var u},findShadowRoot:function(e){if(!document.documentElement.attachShadow)return null
 if("function"==typeof e.getRootNode){var t=e.getRootNode()
 return t instanceof ShadowRoot?t:null}return e instanceof ShadowRoot?e:e.parentNode?r.findShadowRoot(e.parentNode):null}}
-return e.fn.emulateTransitionEnd=n,e.event.special[r.TRANSITION_END]={bindType:t,delegateType:t,handle:function(t){if(e(t.target).is(this))return t.handleObj.handler.apply(this,arguments)}},r}),function(e,t){"object"==typeof exports&&"undefined"!=typeof module?module.exports=t(require("jquery"),require("./util.js")):"function"==typeof define&&define.amd?define(["jquery","./util.js"],t):e.Modal=t(e.jQuery,e.Util)}(this,function(e,t){"use strict"
GitHub sha: fa81f7f0
