DEV: Update jquery.fileupload and dependencies (#9466)
diff --git a/lib/tasks/javascript.rake b/lib/tasks/javascript.rake
index 3f3e969..d538183 100644
--- a/lib/tasks/javascript.rake
+++ b/lib/tasks/javascript.rake
@@ -62,6 +62,12 @@ task 'javascript:update' do
       source: 'jquery.cookie/jquery.cookie.js'
+      source: 'blueimp-file-upload/js/jquery.fileupload.js',
+      source: 'blueimp-file-upload/js/jquery.iframe-transport.js',
+      source: 'blueimp-file-upload/js/vendor/jquery.ui.widget.js',
       source: 'jquery/dist/jquery.js'
       source: 'jquery-tags-input/src/jquery.tagsinput.js'
diff --git a/package.json b/package.json
index eeafd9e..8c25185 100644
--- a/package.json
+++ b/package.json
@@ -9,6 +9,7 @@
     "@fortawesome/fontawesome-free": "5.11.2",
     "@popperjs/core": "v2.0.6",
     "ace-builds": "1.4.2",
+    "blueimp-file-upload": "10.13.0",
     "bootbox": "3.2.0",
     "bootstrap": "v3.4.1",
     "chart.js": "2.9.3",
diff --git a/vendor/assets/javascripts/jquery.fileupload.js b/vendor/assets/javascripts/jquery.fileupload.js
index e99f309..f75cf2b 100644
--- a/vendor/assets/javascripts/jquery.fileupload.js
+++ b/vendor/assets/javascripts/jquery.fileupload.js
@@ -1,1466 +1,1597 @@
- * jQuery File Upload Plugin 5.42.2
+ * jQuery File Upload Plugin
  * https://github.com/blueimp/jQuery-File-Upload
  * Copyright 2010, Sebastian Tschan
  * https://blueimp.net
  * Licensed under the MIT license:
- * http://www.opensource.org/licenses/MIT
+ * https://opensource.org/licenses/MIT
-/* jshint nomen:false */
-/* global define, require, window, document, location, Blob, FormData */
+/* global define, require */
+/* eslint-disable new-cap */
 (function (factory) {
-    'use strict';
-    if (typeof define === 'function' && define.amd) {
-        // Register as an anonymous AMD module:
-        define([
-            'jquery',
-            'jquery.ui.widget'
-        ], factory);
-    } else if (typeof exports === 'object') {
-        // Node/CommonJS:
-        factory(
-            require('jquery'),
-            require('./vendor/jquery.ui.widget')
-    } else {
-        // Browser globals:
-        factory(window.jQuery);
-}(function ($) {
-    'use strict';
-    // Detect file input support, based on
-    // http://viljamis.com/blog/2012/file-upload-support-on-mobile/
-    $.support.fileInput = !(new RegExp(
-        // Handle devices which give false positives for the feature detection:
-        '(Android (1\\.[0156]|2\\.[01]))' +
-            '|(Windows Phone (OS 7|8\\.0))|(XBLWP)|(ZuneWP)|(WPDesktop)' +
-            '|(w(eb)?OSBrowser)|(webOS)' +
-            '|(Kindle/(1\\.0|2\\.[05]|3\\.0))'
+  'use strict';
+  if (typeof define === 'function' && define.amd) {
+    // Register as an anonymous AMD module:
+    define(['jquery', 'jquery-ui/ui/widget'], factory);
+  } else if (typeof exports === 'object') {
+    // Node/CommonJS:
+    factory(require('jquery'), require('./vendor/jquery.ui.widget'));
+  } else {
+    // Browser globals:
+    factory(window.jQuery);
+})(function ($) {
+  'use strict';
+  // Detect file input support, based on
+  // https://viljamis.com/2012/file-upload-support-on-mobile/
+  $.support.fileInput = !(
+    new RegExp(
+      // Handle devices which give false positives for the feature detection:
+      '(Android (1\\.[0156]|2\\.[01]))' +
+        '|(Windows Phone (OS 7|8\\.0))|(XBLWP)|(ZuneWP)|(WPDesktop)' +
+        '|(w(eb)?OSBrowser)|(webOS)' +
+        '|(Kindle/(1\\.0|2\\.[05]|3\\.0))'
     ).test(window.navigator.userAgent) ||
-        // Feature detection for all other devices:
-        $('<input type="file">').prop('disabled'));
-    // The FileReader API is not actually used, but works as feature detection,
-    // as some Safari versions (5?) support XHR file uploads via the FormData API,
-    // but not non-multipart XHR file uploads.
-    // window.XMLHttpRequestUpload is not available on IE10, so we check for
-    // window.ProgressEvent instead to detect XHR2 file upload capability:
-    $.support.xhrFileUpload = !!(window.ProgressEvent && window.FileReader);
-    $.support.xhrFormDataFileUpload = !!window.FormData;
-    // Detect support for Blob slicing (required for chunked uploads):
-    $.support.blobSlice = window.Blob && (Blob.prototype.slice ||
-        Blob.prototype.webkitSlice || Blob.prototype.mozSlice);
-    // Helper function to create drag handlers for dragover/dragenter/dragleave:
-    function getDragHandler(type) {
-        var isDragOver = type === 'dragover';
-        return function (e) {
-            e.dataTransfer = e.originalEvent && e.originalEvent.dataTransfer;
-            var dataTransfer = e.dataTransfer;
-            if (dataTransfer && $.inArray('Files', dataTransfer.types) !== -1 &&
-                    this._trigger(
-                        type,
-                        $.Event(type, {delegatedEvent: e})
-                    ) !== false) {
-                e.preventDefault();
-                if (isDragOver) {
-                    dataTransfer.dropEffect = 'copy';
-    // The fileupload widget listens for change events on file input fields defined
-    // via fileInput setting and paste or drop events of the given dropZone.
-    // In addition to the default jQuery Widget methods, the fileupload widget
-    // exposes the "add" and "send" methods, to add or directly send files using
-    // the fileupload API.
-    // By default, files added via file input selection, paste, drag & drop or
-    // "add" method are uploaded immediately, but it is possible to override
-    // the "add" callback option to queue file uploads.
-    $.widget('blueimp.fileupload', {
-        options: {
-            // The drop target element(s), by the default the complete document.
-            // Set to null to disable drag & drop support:
-            dropZone: $(document),
-            // The paste target element(s), by the default undefined.
-            // Set to a DOM node or jQuery object to enable file pasting:
-            pasteZone: undefined,
-            // The file input field(s), that are listened to for change events.
-            // If undefined, it is set to the file input fields inside
-            // of the widget element on plugin initialization.
-            // Set to null to disable the change listener.
-            fileInput: undefined,
-            // By default, the file input field is replaced with a clone after
-            // each input field change event. This is required for iframe transport
-            // queues and allows change events to be fired for the same file
-            // selection, but can be disabled by setting the following option to false:
-            replaceFileInput: true,
-            // The parameter name for the file form data (the request argument name).
-            // If undefined or empty, the name property of the file input field is
-            // used, or "files[]" if the file input name property is also empty,
-            // can be a string or an array of strings:
-            paramName: undefined,
-            // By default, each file of a selection is uploaded using an individual
-            // request for XHR type uploads. Set to false to upload file
-            // selections in one request each:
-            singleFileUploads: true,
-            // To limit the number of files uploaded with one XHR request,
-            // set the following option to an integer greater than 0:
-            limitMultiFileUploads: undefined,
-            // The following option limits the number of files uploaded with one
-            // XHR request to keep the request size under or equal to the defined
-            // limit in bytes:
-            limitMultiFileUploadSize: undefined,
-            // Multipart file uploads add a number of bytes to each uploaded file,
GitHub sha: ec2943c5
This commit appears in #9466 which was approved by eviltrout. It was merged by pmusaraj.
