DEV: Update lodash from 4.17.15 to 4.17.21 (#13045)
We’re dropping lodash from core after the next release, but until then let’s keep it up to date.
diff --git a/package.json b/package.json
index 77b118f..6dbc0f7 100644
--- a/package.json
+++ b/package.json
@@ -7,6 +7,7 @@
   "license": "GPL-2.0-only",
   "dependencies": {
     "@fortawesome/fontawesome-free": "5.11.2",
+    "@highlightjs/cdn-assets": "^10.6.0",
     "@json-editor/json-editor": "^2.5.2",
     "@popperjs/core": "v2.0.6",
     "ace-builds": "1.4.12",
@@ -18,7 +19,6 @@
     "diffhtml": "^1.0.0-beta.18",
     "eslint-config-discourse": "^1.1.8",
     "handlebars": "^4.7.7",
-    "@highlightjs/cdn-assets": "^10.6.0",
     "intersection-observer": "^0.5.1",
     "jquery": "3.5.1",
     "jquery-color": "3.0.0-alpha.1",
@@ -41,8 +41,8 @@
     "workbox-sw": "^4.3.1"
   "devDependencies": {
-    "@mixer/parallel-prettier": "^2.0.1",
     "@arkweid/lefthook": "^0.7.2",
+    "@mixer/parallel-prettier": "^2.0.1",
     "chrome-launcher": "^0.12.0",
     "chrome-remote-interface": "^0.25",
     "lodash-cli": "https://github.com/lodash-archive/lodash-cli.git",
@@ -52,6 +52,9 @@
     "route-recognizer": "^0.3.3",
     "sinon": "^9.0.2"
+  "resolutions": {
+    "lodash": "4.17.21"
   "scripts": {
     "preinstall": "node -e \"if(process.env.npm_execpath.indexOf('yarn') === -1) throw new Error('NPM is not supported, please use Yarn instead. ')\"",
     "postinstall": "yarn --cwd app/assets/javascripts/discourse"
diff --git a/vendor/assets/javascripts/lodash.js b/vendor/assets/javascripts/lodash.js
index 1029863..9f35238 100644
--- a/vendor/assets/javascripts/lodash.js
+++ b/vendor/assets/javascripts/lodash.js
@@ -13,7 +13,7 @@
   var undefined;
   /** Used as the semantic version number. */
-  var VERSION = '4.17.15';
+  var VERSION = '4.17.21';
   /** Used as the size to enable large array optimizations. */
   var LARGE_ARRAY_SIZE = 200;
@@ -127,8 +127,11 @@
   var reRegExpChar = /[\\^$.*+?()[\]{}|]/g;
-  /** Used to match leading and trailing whitespace. */
-  var reTrim = /^\s+|\s+$/g;
+  /** Used to match leading whitespace. */
+  var reTrimStart = /^\s+/;
+  /** Used to match a single whitespace character. */
+  var reWhitespace = /\s/;
   /** Used to match wrap detail comments. */
   var reWrapComment = /\{(?:\n\/\* \[wrapped with .+\] \*\/)?\n?/,
@@ -629,6 +632,19 @@
+   * The base implementation of `_.trim`.
+   * @private
+   * @param {string} string The string to trim.
+   * @returns {string} Returns the trimmed string.
+  function baseTrim(string) {
+    return string
+      ? string.slice(0, trimmedEndIndex(string) + 1).replace(reTrimStart, '')
+      : string;
    * The base implementation of `_.unary` without support for storing metadata.
    * @private
@@ -838,6 +854,21 @@
+   * Used by `_.trim` and `_.trimEnd` to get the index of the last non-whitespace
+   * character of `string`.
+   * @private
+   * @param {string} string The string to inspect.
+   * @returns {number} Returns the index of the last non-whitespace character.
+  function trimmedEndIndex(string) {
+    var index = string.length;
+    while (index-- && reWhitespace.test(string.charAt(index))) {}
+    return index;
    * Converts a Unicode `string` to an array.
    * @private
@@ -2824,8 +2855,21 @@
    * @returns {Array} Returns the new sorted array.
   function baseOrderBy(collection, iteratees, orders) {
+    if (iteratees.length) {
+      iteratees = arrayMap(iteratees, function(iteratee) {
+        if (isArray(iteratee)) {
+          return function(value) {
+            return baseGet(value, iteratee.length === 1 ? iteratee[0] : iteratee);
+        return iteratee;
+    } else {
+      iteratees = [identity];
     var index = -1;
-    iteratees = arrayMap(iteratees.length ? iteratees : [identity], baseUnary(getIteratee()));
+    iteratees = arrayMap(iteratees, baseUnary(getIteratee()));
     var result = baseMap(collection, function(value, key, collection) {
       var criteria = arrayMap(iteratees, function(iteratee) {
@@ -2952,6 +2996,10 @@
       var key = toKey(path[index]),
           newValue = value;
+      if (key === '__proto__' || key === 'constructor' || key === 'prototype') {
+        return object;
       if (index != lastIndex) {
         var objValue = nested[key];
         newValue = customizer ? customizer(objValue, key, nested) : undefined;
@@ -3826,10 +3874,11 @@
     if (arrLength != othLength && !(isPartial && othLength > arrLength)) {
       return false;
-    // Assume cyclic values are equal.
-    var stacked = stack.get(array);
-    if (stacked && stack.get(other)) {
-      return stacked == other;
+    // Check that cyclic values are equal.
+    var arrStacked = stack.get(array);
+    var othStacked = stack.get(other);
+    if (arrStacked && othStacked) {
+      return arrStacked == other && othStacked == array;
     var index = -1,
         result = true,
@@ -3991,10 +4040,11 @@
         return false;
-    var stacked = stack.get(object);
+    var objStacked = stack.get(object);
+    if (objStacked && othStacked) {
+      return objStacked == other && othStacked == object;
     var result = true;
     stack.set(object, other);
@@ -5596,6 +5646,10 @@
    * // The `_.property` iteratee shorthand.
    * _.filter(users, 'active');
    * // => objects for ['barney']
+   * // Combining several predicates using `_.overEvery` or `_.overSome`.
+   * _.filter(users, _.overSome([{ 'age': 36 }, ['age', 40]]));
+   * // => objects for ['fred', 'barney']
   function filter(collection, predicate) {
     var func = isArray(collection) ? arrayFilter : baseFilter;
@@ -5855,15 +5909,15 @@
    * var users = [
    *   { 'user': 'fred',   'age': 48 },
    *   { 'user': 'barney', 'age': 36 },
-   *   { 'user': 'fred',   'age': 40 },
+   *   { 'user': 'fred',   'age': 30 },
    *   { 'user': 'barney', 'age': 34 }
    * _.sortBy(users, [function(o) { return o.user; }]);
-   * // => objects for [['barney', 36], ['barney', 34], ['fred', 48], ['fred', 40]]
+   * // => objects for [['barney', 36], ['barney', 34], ['fred', 48], ['fred', 30]]
    * _.sortBy(users, ['user', 'age']);
-   * // => objects for [['barney', 34], ['barney', 36], ['fred', 40], ['fred', 48]]
+   * // => objects for [['barney', 34], ['barney', 36], ['fred', 30], ['fred', 48]]
   var sortBy = baseRest(function(collection, iteratees) {
     if (collection == null) {
@@ -6953,7 +7007,7 @@
     if (typeof value != 'string') {
       return value === 0 ? value : +value;
-    value = value.replace(reTrim, '');
+    value = baseTrim(value);
     var isBinary = reIsBinary.test(value);
     return (isBinary || reIsOctal.test(value))
       ? freeParseInt(value.slice(2), isBinary ? 2 : 8)
diff --git a/yarn.lock b/yarn.lock
index 1640457..c207206 100644
--- a/yarn.lock
+++ b/yarn.lock
@@ -2163,15 +2163,10 @@ lodash.get@^4.4.2:
   resolved "https://registry.yarnpkg.com/lodash.get/-/lodash.get-4.4.2.tgz#2d177f652fa31e939b4438d5341499dfa3825e99"
   integrity sha1-LRd/ZS+jHpObRDjVNBSZ36OCXpk=
-lodash@4.17.15:
-  version "4.17.15"
-  resolved "https://registry.yarnpkg.com/lodash/-/lodash-4.17.15.tgz#b447f6670a0455bbfeedd11392eff330ea097548"
-  integrity sha512-8xOcRHvCjnocdS5cpwXQXVzmmh5e5+saE2QGoeQmbKmRS6J3VQppPOIt0MnmE+4xlZoumy0GPG0D0MVIQbNA1A==
-lodash@^4.17.14, lodash@^4.17.19:
-  version "4.17.20"
-  resolved "https://registry.yarnpkg.com/lodash/-/lodash-4.17.20.tgz#b44a9b6297bcb698f1c51a3545a2b3b368d59c52"
-  integrity sha512-PlhdFcillOINfeV7Ni6oF1TAEayyZBoZ8bcshTHqOYJYlrqzRK5hagpagky5o4HfCzzd1TRkXPMFq6cKk9rGmA==
+lodash@4.17.21, lodash@^4.17.14, lodash@^4.17.19:
+  version "4.17.21"
GitHub sha: 2cf063dc
This commit appears in #13045 which was approved by eviltrout. It was merged by CvX.
