DEV: Update rubocop-discourse (#9270)
Includes:
  • DEV: Use eq_time matcher
diff --git a/.rubocop.yml b/.rubocop.yml
index 1e682c1..f9dafa6 100644
--- a/.rubocop.yml
+++ b/.rubocop.yml
@@ -12,6 +12,14 @@ AllCops:
     - "public/**/*"
     - "plugins/**/gems/**/*"
+Discourse:
+  Enabled: true
+Discourse/NoChdir:
+  Exclude:
+    - 'spec/**/*' # Specs are run sequentially, so chdir can be used
+    - 'plugins/*/spec/**/*'
 # Prefer &&/|| over and/or.
 Style/AndOr:
   Enabled: true
@@ -127,15 +135,6 @@ Style/Semicolon:
 Style/RedundantReturn:
   Enabled: true
-DiscourseCops/NoChdir:
-  Enabled: true
-  Exclude:
-    - 'spec/**/*' # Specs are run sequentially, so chdir can be used
-    - 'plugins/*/spec/**/*'
-DiscourseCops/NoURIEscapeEncode:
-  Enabled: true
 Style/GlobalVars:
   Enabled: true
   Severity: warning
index 08056d6..cc1ebd6 100644
--- a/Gemfile.lock
+++ b/Gemfile.lock
@@ -253,7 +253,7 @@ GEM
     parallel (1.19.1)
     parallel_tests (2.32.0)
       parallel
-    parser (2.7.0.4)
+    parser (2.7.0.5)
       ast (~> 2.4.0)
     pg (1.2.3)
     progress (3.5.2)
@@ -348,7 +348,7 @@ GEM
       rexml
       ruby-progressbar (~> 1.7)
       unicode-display_width (>= 1.4.0, < 1.7)
-    rubocop-discourse (1.0.2)
+    rubocop-discourse (2.0.1)
       rubocop (>= 0.69.0)
     ruby-prof (1.3.1)
     ruby-progressbar (1.10.1)
diff --git a/lib/autospec/simple_runner.rb b/lib/autospec/simple_runner.rb
index 1f944d9..a5c295d 100644
--- a/lib/autospec/simple_runner.rb
+++ b/lib/autospec/simple_runner.rb
@@ -32,7 +32,7 @@ module Autospec
       # launch rspec
-      Dir.chdir(Rails.root) do # rubocop:disable DiscourseCops/NoChdir because this is not part of the app
+      Dir.chdir(Rails.root) do # rubocop:disable Discourse/NoChdir because this is not part of the app
         env = { "RAILS_ENV" => "test" }
         if specs.split(' ').any? { |s| s =~ /^(.\/)?plugins/ }
           env["LOAD_PLUGINS"] = "1"
diff --git a/script/plugin-translations.rb b/script/plugin-translations.rb
index 78535b4..87bf4e8 100644
--- a/script/plugin-translations.rb
+++ b/script/plugin-translations.rb
@@ -42,7 +42,7 @@ class PluginTxUpdater
     PLUGINS.each do |plugin_name|
       plugin_dir = File.join(@base_dir, plugin_name)
       Bundler.with_clean_env do
-        Dir.chdir(plugin_dir) do # rubocop:disable DiscourseCops/NoChdir because this is not part of the app
+        Dir.chdir(plugin_dir) do # rubocop:disable Discourse/NoChdir because this is not part of the app
           puts '', plugin_dir, '-' * 80, ''
           begin
diff --git a/spec/lib/bookmark_manager_spec.rb b/spec/lib/bookmark_manager_spec.rb
index 11a0b7d..a19380b 100644
--- a/spec/lib/bookmark_manager_spec.rb
+++ b/spec/lib/bookmark_manager_spec.rb
@@ -6,7 +6,7 @@ RSpec.describe BookmarkManager do
   let(:user) { Fabricate(:user) }
   let(:reminder_type) { 'tomorrow' }
-  let(:reminder_at) { (Time.zone.now + 1.day).iso8601 }
+  let(:reminder_at) { 1.day.from_now }
   fab!(:post) { Fabricate(:post) }
   let(:name) { 'Check this out!' }
@@ -26,7 +26,7 @@ RSpec.describe BookmarkManager do
         subject.create(post_id: post.id, name: name, reminder_type: reminder_type, reminder_at: reminder_at)
         bookmark = Bookmark.find_by(user: user)
-        expect(bookmark.reminder_at).to eq(reminder_at)
+        expect(bookmark.reminder_at).to eq_time(reminder_at)
         expect(bookmark.reminder_set_at).not_to eq(nil)
         expect(bookmark.reminder_type).to eq(Bookmark.reminder_types[:tomorrow])
@@ -76,7 +76,8 @@ RSpec.describe BookmarkManager do
     context "when the reminder time is in the past" do
-      let(:reminder_at) { (Time.zone.now - 10.days).iso8601 }
+      let(:reminder_at) { 10.days.ago }
       it "adds an error to the manager" do
         expect(subject.errors.full_messages).to include(I18n.t("bookmarks.errors.cannot_set_past_reminder"))
@@ -84,7 +85,8 @@ RSpec.describe BookmarkManager do
     context "when the reminder time is far-flung (> 10 years from now)" do
-      let(:reminder_at) { (Time.zone.now + 11.years).iso8601 }
+      let(:reminder_at) { 11.years.from_now }
         expect(subject.errors.full_messages).to include(I18n.t("bookmarks.errors.cannot_set_reminder_in_distant_future"))
diff --git a/spec/models/post_spec.rb b/spec/models/post_spec.rb
index 66ba358..4cc716d 100644
--- a/spec/models/post_spec.rb
+++ b/spec/models/post_spec.rb
@@ -1172,7 +1172,7 @@ describe Post do
       result = post.rebake!
-      expect(post.baked_at).not_to eq(first_baked)
+      expect(post.baked_at).not_to eq_time(first_baked)
       expect(post.cooked).to eq(first_cooked)
       expect(result).to eq(true)
diff --git a/spec/rails_helper.rb b/spec/rails_helper.rb
index 4bc237a..dc649a9 100644
--- a/spec/rails_helper.rb
+++ b/spec/rails_helper.rb
@@ -240,7 +240,7 @@ RSpec.configure do |config|
   config.before :each, &TestSetup.method(:test_setup)
   config.before(:each, type: :multisite) do
-    Rails.configuration.multisite = true
+    Rails.configuration.multisite = true # rubocop:disable Discourse/NoDirectMultisiteManipulation
     RailsMultisite::ConnectionManagement.config_filename =
       "spec/fixtures/multisite/two_dbs.yml"
@@ -248,7 +248,7 @@ RSpec.configure do |config|
   config.after(:each, type: :multisite) do
     ActiveRecord::Base.clear_all_connections!
-    Rails.configuration.multisite = false
+    Rails.configuration.multisite = false # rubocop:disable Discourse/NoDirectMultisiteManipulation
     RailsMultisite::ConnectionManagement.clear_settings!
     ActiveRecord::Base.establish_connection
diff --git a/spec/serializers/user_bookmark_serializer_spec.rb b/spec/serializers/user_bookmark_serializer_spec.rb
index 36b05ab..e97ebfe 100644
--- a/spec/serializers/user_bookmark_serializer_spec.rb
+++ b/spec/serializers/user_bookmark_serializer_spec.rb
@@ -12,12 +12,12 @@ RSpec.describe UserBookmarkSerializer do
     s = UserBookmarkSerializer.new(bookmark_list.last)
     expect(s.id).to eq(bookmark.id)
-    expect(s.created_at).to eq(bookmark.created_at)
+    expect(s.created_at).to eq_time(bookmark.created_at)
     expect(s.topic_id).to eq(bookmark.topic_id)
     expect(s.linked_post_number).to eq(bookmark.post.post_number)
     expect(s.post_id).to eq(bookmark.post_id)
     expect(s.name).to eq(bookmark.name)
-    expect(s.reminder_at).to eq(bookmark.reminder_at)
+    expect(s.reminder_at).to eq_time(bookmark.reminder_at)
     expect(s.title).to eq(bookmark.topic.title)
     expect(s.deleted).to eq(false)
     expect(s.hidden).to eq(false)
@@ -26,7 +26,7 @@ RSpec.describe UserBookmarkSerializer do
     expect(s.category_id).to eq(bookmark.topic.category_id)
     expect(s.archetype).to eq(bookmark.topic.archetype)
     expect(s.highest_post_number).to eq(1)
-    expect(s.bumped_at.to_s).to eq(bookmark.topic.bumped_at.to_s)
+    expect(s.bumped_at).to eq_time(bookmark.topic.bumped_at)
     expect(s.slug).to eq(bookmark.topic.slug)
     expect(s.username).to eq(bookmark.post.user.username)
diff --git a/spec/services/anonymous_shadow_creator_spec.rb b/spec/services/anonymous_shadow_creator_spec.rb
index c47635f..cb5fcb4 100644
--- a/spec/services/anonymous_shadow_creator_spec.rb
+++ b/spec/services/anonymous_shadow_creator_spec.rb
@@ -56,7 +56,7 @@ describe AnonymousShadowCreator do
       expect(shadow.trust_level).to eq(1)
       expect(shadow.username).to eq("anonymous")
-      expect(shadow.created_at).not_to eq(user.created_at)
+      expect(shadow.created_at).not_to eq_time(user.created_at)
       p = create_post
GitHub sha: d21d8019
This commit appears in #9270 which was approved by davidtaylorhq. It was merged by CvX.
@CvX no rush, but looks like this change is affecting the discoure_api gem rubocop which pulls in the discourse/discourse rubocop config? Could also affect other repos that pull in the same file.
If you run bundle exec rake inside the latest discourse_api repo
Running RuboCop...
.rubocop-https---raw-githubusercontent-com-discourse-discourse-master--rubocop-yml: Discourse/NoChdir has the wrong namespace - should be DiscourseCops
Warning: unrecognized cop Discourse found in .rubocop-https---raw-githubusercontent-com-discourse-discourse-master--rubocop-yml
Warning: unrecognized cop Layout/TrailingEmptyLines found in .rubocop-https---raw-githubusercontent-com-discourse-discourse-master--rubocop-yml
Warning: unrecognized cop Layout/HashAlignment found in .rubocop-https---raw-githubusercontent-com-discourse-discourse-master--rubocop-yml
Warning: unrecognized cop Discourse found in .rubocop.yml
Warning: unrecognized cop Layout/TrailingEmptyLines found in .rubocop.yml
Warning: unrecognized cop Layout/HashAlignment found in .rubocop.yml
Inspecting 53 files
Which is apparently causing CI to fail
Travis CI - Test and Deploy Your Code with Confidence
Thoughts?
