DEV: upgrade Ember to 3.8 (#53)
diff --git a/assets/docker-manager-app.js b/assets/docker-manager-app.js
index 1bbc0b0..3123bff 100644
--- a/assets/docker-manager-app.js
+++ b/assets/docker-manager-app.js
@@ -124,7 +124,7 @@ var t=Ember.HTMLBars.template({id:"RuK/j8VC",block:'{"symbols":[],"statements":[
 e.default=t}),define("manager-client/templates/processes",["exports"],function(e){Object.defineProperty(e,"__esModule",{value:!0}),e.default=void 0
 var t=Ember.HTMLBars.template({id:"n/TsMj7R",block:'{"symbols":[],"statements":[[1,[27,"x-console",null,[["output"],[[23,["model","output"]]]]],false],[0,"\\n"]],"hasEval":false}',meta:{moduleName:"manager-client/templates/processes.hbs"}})
 e.default=t}),define("manager-client/templates/upgrade",["exports"],function(e){Object.defineProperty(e,"__esModule",{value:!0}),e.default=void 0
-var t=Ember.HTMLBars.template({id:"22BAD0Z/",block:'{"symbols":[],"statements":[[7,"h3"],[9],[0,"Upgrade "],[1,[21,"title"],false],[10],[0,"\\n\\n"],[1,[27,"progress-bar",null,[["percent"],[[23,["percent"]]]]],false],[0,"\\n\\n"],[4,"if",[[23,["complete"]]],null,{"statements":[[0,"  "],[7,"p"],[9],[0,"Upgrade completed successfully!"],[10],[0,"\\n"]],"parameters":[]},null],[0,"\\n"],[4,"if",[[23,["failed"]]],null,{"statements":[[0,"  "],[7,"p"],[9],[0,"Sorry, there was an error upgrading Discourse. Please check the logs below."],[10],[0,"\\n"]],"parameters":[]},null],[0,"\\n"],[4,"if",[[23,["isUpToDate"]]],null,{"statements":[[4,"unless",[[23,["multiUpgrade"]]],null,{"statements":[[0,"    "],[7,"p"],[9],[1,[21,"title"],false],[0," is at the newest version "],[1,[27,"fmt-commit",[[23,["model","0","version"]],[23,["model","0","url"]],[23,["model","0","branch"]]],null],false],[0,"."],[10],[0,"\\n"]],"parameters":[]},{"statements":[[0,"    "],[7,"p"],[9],[0,"Everything is up-to-date."],[10],[0,"\\n"]],"parameters":[]}]],"parameters":[]},{"statements":[[0,"  "],[7,"div"],[11,"style","clear: both"],[9],[0,"\\n    "],[7,"button"],[12,"disabled",[21,"upgrading"]],[11,"class","btn"],[9],[1,[21,"upgradeButtonText"],false],[3,"action",[[22,0,[]],"start"]],[10],[0,"\\n"],[4,"if",[[23,["upgrading"]]],null,{"statements":[[0,"      "],[7,"button"],[11,"class","btn unlock"],[9],[0,"Reset Upgrade"],[3,"action",[[22,0,[]],"resetUpgrade"]],[10],[0,"\\n"]],"parameters":[]},null],[0,"  "],[10],[0,"\\n"]],"parameters":[]}],[0,"\\n"],[1,[27,"x-console",null,[["output","followOutput"],[[23,["output"]],true]]],false],[0,"\\n"]],"hasEval":false}',meta:{moduleName:"manager-client/templates/upgrade.hbs"}})
-e.default=t}),define("manager-client/config/environment",[],function(){try{var e="manager-client/config/environment",t=document.querySelector('meta[name="'+e+'"]').getAttribute("content"),n={default:JSON.parse(unescape(t))}
+var t=Ember.HTMLBars.template({id:"H4zT5h6q",block:'{"symbols":[],"statements":[[7,"h3"],[9],[0,"Upgrade "],[1,[21,"title"],false],[10],[0,"\\n\\n"],[1,[27,"progress-bar",null,[["percent"],[[23,["percent"]]]]],false],[0,"\\n\\n"],[4,"if",[[23,["complete"]]],null,{"statements":[[0,"  "],[7,"p"],[9],[0,"Upgrade completed successfully!"],[10],[0,"\\n"]],"parameters":[]},null],[0,"\\n"],[4,"if",[[23,["failed"]]],null,{"statements":[[0,"  "],[7,"p"],[9],[0,"Sorry, there was an error upgrading Discourse. Please check the logs below."],[10],[0,"\\n"]],"parameters":[]},null],[0,"\\n"],[4,"if",[[23,["isUpToDate"]]],null,{"statements":[[4,"unless",[[23,["multiUpgrade"]]],null,{"statements":[[0,"    "],[7,"p"],[9],[1,[21,"title"],false],[0," is at the newest version."],[10],[0,"\\n"]],"parameters":[]},{"statements":[[0,"    "],[7,"p"],[9],[0,"Everything is up-to-date."],[10],[0,"\\n"]],"parameters":[]}]],"parameters":[]},{"statements":[[0,"  "],[7,"div"],[11,"style","clear: both"],[9],[0,"\\n    "],[7,"button"],[12,"disabled",[21,"upgrading"]],[11,"class","btn"],[9],[1,[21,"upgradeButtonText"],false],[3,"action",[[22,0,[]],"start"]],[10],[0,"\\n"],[4,"if",[[23,["upgrading"]]],null,{"statements":[[0,"      "],[7,"button"],[11,"class","btn unlock"],[9],[0,"Reset Upgrade"],[3,"action",[[22,0,[]],"resetUpgrade"]],[10],[0,"\\n"]],"parameters":[]},null],[0,"  "],[10],[0,"\\n"]],"parameters":[]}],[0,"\\n"],[1,[27,"x-console",null,[["output","followOutput"],[[23,["output"]],true]]],false],[0,"\\n"]],"hasEval":false}',meta:{moduleName:"manager-client/templates/upgrade.hbs"}})
+e.default=t}),define("manager-client/config/environment",[],function(){try{var e="manager-client/config/environment",t=document.querySelector('meta[name="'+e+'"]').getAttribute("content"),n={default:JSON.parse(decodeURIComponent(t))}
 return Object.defineProperty(n,"__esModule",{value:!0}),n}catch(r){throw new Error('Could not read config from meta tag with name "'+e+'".')}})
-runningTests||require("manager-client/app").default.create({name:"manager-client",version:"0.0.0+a82159de"})
+runningTests||require("manager-client/app").default.create({name:"manager-client",version:"0.0.0+0e6fee4d"})
diff --git a/assets/docker-manager-vendor.js b/assets/docker-manager-vendor.js
index e99d3d1..6cebcf5 100644
--- a/assets/docker-manager-vendor.js
+++ b/assets/docker-manager-vendor.js
@@ -1,2074 +1,2256 @@
 window.EmberENV={FEATURES:{},EXTEND_PROTOTYPES:{Date:!1}}
 var loader,define,requireModule,require,requirejs,runningTests=!1
-function createDeprecatedModule(e){define(e,["exports","ember-resolver/resolver","ember"],function(t,r,n){n.default.deprecate("Usage of `"+e+"` module is deprecated, please update to `ember-resolver`.",!1,{id:"ember-resolver.legacy-shims",until:"3.0.0"}),t.default=r.default})}(function(e){"use strict"
+function createDeprecatedModule(e){define(e,["exports","ember-resolver/resolver","ember"],function(t,n,r){r.default.deprecate("Usage of `"+e+"` module is deprecated, please update to `ember-resolver`.",!1,{id:"ember-resolver.legacy-shims",until:"3.0.0"}),t.default=n.default})}(function(e){"use strict"
 function t(){var e=Object.create(null)
-return e.__=void 0,delete e.__,e}var r={loader:loader,define:define,requireModule:requireModule,require:require,requirejs:requirejs}
-requirejs=require=requireModule=function(e){for(var t=[],r=l(e,"(require)",t),n=t.length-1;n>=0;n--)t[n].exports()
-return r.module.exports},loader={noConflict:function(t){var n,i
-for(n in t)t.hasOwnProperty(n)&&r.hasOwnProperty(n)&&(i=t[n],e[i]=e[n],e[n]=r[n])},makeDefaultExport:!0}
-var n=t(),i=(t(),0)
+return e.__=void 0,delete e.__,e}var n={loader:loader,define:define,requireModule:requireModule,require:require,requirejs:requirejs}
+requirejs=require=requireModule=function(e){for(var t=[],n=l(e,"(require)",t),r=t.length-1;r>=0;r--)t[r].exports()
+return n.module.exports},loader={noConflict:function(t){var r,i
+for(r in t)t.hasOwnProperty(r)&&n.hasOwnProperty(r)&&(i=t[r],e[i]=e[r],e[r]=n[r])},makeDefaultExport:!0}
+var r=t(),i=(t(),0)
 var o=["require","exports","module"]
-function s(e,t,r,n){this.uuid=i++,this.id=e,this.deps=!t.length&&r.length?o:t,this.module={exports:{}},this.callback=r,this.hasExportsAsDep=!1,this.isAlias=n,this.reified=new Array(t.length),this.state="new"}function a(){}function u(e){this.id=e}function l(e,t,r){for(var i=n[e]||n[e+"/index"];i&&i.isAlias;)i=n[i.id]||n[i.id+"/index"]
-return i||function(e,t){throw new Error("Could not find module `"+e+"` imported from `"+t+"`")}(e,t),r&&"pending"!==i.state&&"finalized"!==i.state&&(i.findDeps(r),r.push(i)),i}function c(e,t){if("."!==e.charAt(0))return e
-for(var r=e.split("/"),n=t.split("/").slice(0,-1),i=0,o=r.length;i<o;i++){var s=r[i]
-if(".."===s){if(0===n.length)throw new Error("Cannot access parent module of root")
-n.pop()}else{if("."===s)continue
-n.push(s)}}return n.join("/")}function h(e){return!(!n[e]&&!n[e+"/index"])}s.prototype.makeDefaultExport=function(){var e=this.module.exports
-null===e||"object"!=typeof e&&"function"!=typeof e||void 0!==e.default||!Object.isExtensible(e)||(e.default=e)},s.prototype.exports=function(){if("finalized"===this.state||"reifying"===this.state)return this.module.exports
GitHub sha: 21b022b1
