DEV: upgrade Rails
DEV: upgrade Rails
Latest version of Rails contains compatibility fixes for Ruby 2.7 and some minor security fixes we would like to have
It also broke some of the multisite tests.
Rails tries to use the same connection for reading from a replica as writing to the leader during tests, because, with everything happening in a transaction, changes to the DB wouldn’t otherwise be reflected in the replica connection.
The difference now is that Rails tries to do this for connections opened after the test has started which affected rails multisite connections.
The upshot of this is that, as things stand, you are likely to experience problems if you try to connect to a different multisite DB in a test when the current_db is not ‘default’.
diff --git a/Gemfile b/Gemfile
index 9e4b7cb..d0844e4 100644
--- a/Gemfile
+++ b/Gemfile
@@ -18,13 +18,13 @@ else
   # this allows us to include the bits of rails we use without pieces we do not.
   # To issue a rails update bump the version number here
-  gem 'actionmailer', '6.0.1'
-  gem 'actionpack', '6.0.1'
-  gem 'actionview', '6.0.1'
-  gem 'activemodel', '6.0.1'
-  gem 'activerecord', '6.0.1'
-  gem 'activesupport', '6.0.1'
-  gem 'railties', '6.0.1'
+  gem 'actionmailer', '6.0.2.2'
+  gem 'actionpack', '6.0.2.2'
+  gem 'actionview', '6.0.2.2'
+  gem 'activemodel', '6.0.2.2'
+  gem 'activerecord', '6.0.2.2'
+  gem 'activesupport', '6.0.2.2'
+  gem 'railties', '6.0.2.2'
   gem 'sprockets-rails'
index ef1c3e6..fa01058 100644
--- a/Gemfile.lock
+++ b/Gemfile.lock
@@ -1,21 +1,21 @@
 GEM
   remote: https://rubygems.org/
   specs:
-    actionmailer (6.0.1)
-      actionpack (= 6.0.1)
-      actionview (= 6.0.1)
-      activejob (= 6.0.1)
+    actionmailer (6.0.2.2)
+      actionpack (= 6.0.2.2)
+      actionview (= 6.0.2.2)
+      activejob (= 6.0.2.2)
       mail (~> 2.5, >= 2.5.4)
       rails-dom-testing (~> 2.0)
-    actionpack (6.0.1)
-      activesupport (= 6.0.1)
-      rack (~> 2.0)
+    actionpack (6.0.2.2)
+      activesupport (= 6.0.2.2)
+      rack (~> 2.0, >= 2.0.8)
       rack-test (>= 0.6.3)
       rails-html-sanitizer (~> 1.0, >= 1.2.0)
-    actionview (6.0.1)
+    actionview (6.0.2.2)
       builder (~> 3.1)
       erubi (~> 1.4)
@@ -24,15 +24,15 @@ GEM
       actionview (>= 6.0.a)
     active_model_serializers (0.8.4)
       activemodel (>= 3.0)
-    activejob (6.0.1)
+    activejob (6.0.2.2)
       globalid (>= 0.3.6)
-    activemodel (6.0.1)
-    activerecord (6.0.1)
-      activemodel (= 6.0.1)
-    activesupport (6.0.1)
+    activemodel (6.0.2.2)
+    activerecord (6.0.2.2)
+      activemodel (= 6.0.2.2)
+    activesupport (6.0.2.2)
       concurrent-ruby (~> 1.0, >= 1.0.2)
       i18n (>= 0.7, < 2)
       minitest (~> 5.1)
@@ -283,9 +283,9 @@ GEM
     rails_multisite (2.1.1)
       activerecord (> 5.0, < 7)
       railties (> 5.0, < 7)
-    railties (6.0.1)
+    railties (6.0.2.2)
       method_source
       rake (>= 0.8.7)
       thor (>= 0.20.3, < 2.0)
@@ -425,14 +425,14 @@ PLATFORMS
   ruby
 DEPENDENCIES
-  actionmailer (= 6.0.1)
+  actionmailer (= 6.0.2.2)
   actionview_precompiler
   active_model_serializers (~> 0.8.3)
-  activerecord (= 6.0.1)
+  activerecord (= 6.0.2.2)
   addressable
   annotate
   aws-sdk-s3
@@ -512,7 +512,7 @@ DEPENDENCIES
   rack-mini-profiler
   rack-protection
   rails_multisite
-  railties (= 6.0.1)
+  railties (= 6.0.2.2)
   rake
   rb-fsevent
   rb-inotify (~> 0.9)
diff --git a/spec/rails_helper.rb b/spec/rails_helper.rb
index 011dc03..04a90b3 100644
--- a/spec/rails_helper.rb
+++ b/spec/rails_helper.rb
@@ -244,6 +244,8 @@ RSpec.configure do |config|
     RailsMultisite::ConnectionManagement.config_filename =
       "spec/fixtures/multisite/two_dbs.yml"
+    RailsMultisite::ConnectionManagement.establish_connection(db: 'default')
   config.after(:each, type: :multisite) do
GitHub sha: 7876ee2d
