DEV: upgrades highlight.js from v9.12.0 to v9.13.1
From f94c3aef7b4f0ee5d95db2752854d5811c0cc35a Mon Sep 17 00:00:00 2001
Date: Fri, 30 Nov 2018 18:07:06 +0100
Subject: [PATCH] DEV: upgrades highlight.js from v9.12.0 to v9.13.1
diff --git a/lib/highlight_js/assets/highlight.js b/lib/highlight_js/assets/highlight.js
index d59bc7c..a7fd82e 100644
--- a/lib/highlight_js/assets/highlight.js
+++ b/lib/highlight_js/assets/highlight.js
@@ -1,2 +1,2 @@
-/*! highlight.js v9.12.0 | BSD3 License | git.io/hljslicense */
-!function(e){var n="object"==typeof window&&window||"object"==typeof self&&self;"undefined"!=typeof exports?e(exports):n&&(n.hljs=e({}),"function"==typeof define&&define.amd&&define([],function(){return n.hljs}))}(function(e){function n(e){return e.replace(/&/g,"&amp;").replace(/</g,"&lt;").replace(/>/g,"&gt;")}function t(e){return e.nodeName.toLowerCase()}function r(e,n){var t=e&&e.exec(n);return t&&0===t.index}function a(e){return k.test(e)}function i(e){var n,t,r,i,o=e.className+" ";if(o+=e.parentNode?e.parentNode.className:"",t=B.exec(o))return w(t[1])?t[1]:"no-highlight";for(o=o.split(/\s+/),n=0,r=o.length;r>n;n++)if(i=o[n],a(i)||w(i))return i}function o(e){var n,t={},r=Array.prototype.slice.call(arguments,1);for(n in e)t[n]=e[n];return r.forEach(function(e){for(n in e)t[n]=e[n]}),t}function u(e){var n=[];return function r(e,a){for(var i=e.firstChild;i;i=i.nextSibling)3===i.nodeType?a+=i.nodeValue.length:1===i.nodeType&&(n.push({event:"start",offset:a,node:i}),a=r(i,a),t(i).match(/br|hr|img|input/)||n.push({event:"stop",offset:a,node:i}));return a}(e,0),n}function c(e,r,a){function i(){return e.length&&r.length?e[0].offset!==r[0].offset?e[0].offset<r[0].offset?e:r:"start"===r[0].event?e:r:e.length?e:r}function o(e){function r(e){return" "+e.nodeName+'="'+n(e.value).replace('"',"&quot;")+'"'}l+="<"+t(e)+E.map.call(e.attributes,r).join("")+">"}function u(e){l+="</"+t(e)+">"}function c(e){("start"===e.event?o:u)(e.node)}for(var s=0,l="",f=[];e.length||r.length;){var g=i();if(l+=n(a.substring(s,g[0].offset)),s=g[0].offset,g===e){f.reverse().forEach(u);do c(g.splice(0,1)[0]),g=i();while(g===e&&g.length&&g[0].offset===s);f.reverse().forEach(o)}else"start"===g[0].event?f.push(g[0].node):f.pop(),c(g.splice(0,1)[0])}return l+n(a.substr(s))}function s(e){return e.v&&!e.cached_variants&&(e.cached_variants=e.v.map(function(n){return o(e,{v:null},n)})),e.cached_variants||e.eW&&[o(e)]||[e]}function l(e){function n(e){return e&&e.source||e}function t(t,r){return new RegExp(n(t),"m"+(e.cI?"i":"")+(r?"g":""))}function r(a,i){if(!a.compiled){if(a.compiled=!0,a.k=a.k||a.bK,a.k){var o={},u=function(n,t){e.cI&&(t=t.toLowerCase()),t.split(" ").forEach(function(e){var t=e.split("|");o[t[0]]=[n,t[1]?Number(t[1]):1]})};"string"==typeof a.k?u("keyword",a.k):x(a.k).forEach(function(e){u(e,a.k[e])}),a.k=o}a.lR=t(a.l||/\w+/,!0),i&&(a.bK&&(a.b="\\b("+a.bK.split(" ").join("|")+")\\b"),a.b||(a.b=/\B|\b/),a.bR=t(a.b),a.e||a.eW||(a.e=/\B|\b/),a.e&&(a.eR=t(a.e)),a.tE=n(a.e)||"",a.eW&&i.tE&&(a.tE+=(a.e?"|":"")+i.tE)),a.i&&(a.iR=t(a.i)),null==a.r&&(a.r=1),a.c||(a.c=[]),a.c=Array.prototype.concat.apply([],a.c.map(function(e){return s("self"===e?a:e)})),a.c.forEach(function(e){r(e,a)}),a.starts&&r(a.starts,i);var c=a.c.map(function(e){return e.bK?"\\.?("+e.b+")\\.?":e.b}).concat([a.tE,a.i]).map(n).filter(Boolean);a.t=c.length?t(c.join("|"),!0):{exec:function(){return null}}}}r(e)}function f(e,t,a,i){function o(e,n){var t,a;for(t=0,a=n.c.length;a>t;t++)if(r(n.c[t].bR,e))return n.c[t]}function u(e,n){if(r(e.eR,n)){for(;e.endsParent&&e.parent;)e=e.parent;return e}return e.eW?u(e.parent,n):void 0}function c(e,n){return!a&&r(n.iR,e)}function s(e,n){var t=N.cI?n[0].toLowerCase():n[0];return e.k.hasOwnProperty(t)&&e.k[t]}function p(e,n,t,r){var a=r?"":I.classPrefix,i='<span class="'+a,o=t?"":C;return i+=e+'">',i+n+o}function h(){var e,t,r,a;if(!E.k)return n(k);for(a="",t=0,E.lR.lastIndex=0,r=E.lR.exec(k);r;)a+=n(k.substring(t,r.index)),e=s(E,r),e?(B+=e[1],a+=p(e[0],n(r[0]))):a+=n(r[0]),t=E.lR.lastIndex,r=E.lR.exec(k);return a+n(k.substr(t))}function d(){var e="string"==typeof E.sL;if(e&&!L[E.sL])return n(k);var t=e?f(E.sL,k,!0,x[E.sL]):g(k,E.sL.length?E.sL:void 0);return E.r>0&&(B+=t.r),e&&(x[E.sL]=t.top),p(t.language,t.value,!1,!0)}function b(){y+=null!=E.sL?d():h(),k=""}function v(e){y+=e.cN?p(e.cN,"",!0):"",E=Object.create(e,{parent:{value:E}})}function m(e,n){if(k+=e,null==n)return b(),0;var t=o(n,E);if(t)return t.skip?k+=n:(t.eB&&(k+=n),b(),t.rB||t.eB||(k=n)),v(t,n),t.rB?0:n.length;var r=u(E,n);if(r){var a=E;a.skip?k+=n:(a.rE||a.eE||(k+=n),b(),a.eE&&(k=n));do E.cN&&(y+=C),E.skip||E.sL||(B+=E.r),E=E.parent;while(E!==r.parent);return r.starts&&v(r.starts,""),a.rE?0:n.length}if(c(n,E))throw new Error('Illegal lexeme "'+n+'" for mode "'+(E.cN||"<unnamed>")+'"');return k+=n,n.length||1}var N=w(e);if(!N)throw new Error('Unknown language: "'+e+'"');l(N);var R,E=i||N,x={},y="";for(R=E;R!==N;R=R.parent)R.cN&&(y=p(R.cN,"",!0)+y);var k="",B=0;try{for(var M,j,O=0;;){if(E.t.lastIndex=O,M=E.t.exec(t),!M)break;j=m(t.substring(O,M.index),M[0]),O=M.index+j}for(m(t.substr(O)),R=E;R.parent;R=R.parent)R.cN&&(y+=C);return{r:B,value:y,language:e,top:E}}catch(T){if(T.message&&-1!==T.message.indexOf("Illegal"))return{r:0,value:n(t)};throw T}}function g(e,t){t=t||I.languages||x(L);var r={r:0,value:n(e)},a=r;return t.filter(w).forEach(function(n){var t=f(n,e,!1);t.language=n,t.r>a.r&&(a=t),t.r>r.r&&(a=r,r=t)}),a.language&&(r.second_best=a),r}function p(e){return I.tabReplace||I.useBR?e.replace(M,function(e,n){return I.useBR&&"\n"===e?"<br>":I.tabReplace?n.replace(/\t/g,I.tabReplace):""}):e}function h(e,n,t){var r=n?y[n]:t,a=[e.trim()];return e.match(/\bhljs\b/)||a.push("hljs"),-1===e.indexOf(r)&&a.push(r),a.join(" ").trim()}function d(e){var n,t,r,o,s,l=i(e);a(l)||(I.useBR?(n=document.createElementNS("http://www.w3.org/1999/xhtml","div"),n.innerHTML=e.innerHTML.replace(/\n/g,"").replace(/<br[ \/]*>/g,"\n")):n=e,s=n.textContent,r=l?f(l,s,!0):g(s),t=u(n),t.length&&(o=document.createElementNS("http://www.w3.org/1999/xhtml","div"),o.innerHTML=r.value,r.value=c(t,u(o),s)),r.value=p(r.value),e.innerHTML=r.value,e.className=h(e.className,l,r.language),e.result={language:r.language,re:r.r},r.second_best&&(e.second_best={language:r.second_best.language,re:r.second_best.r}))}function b(e){I=o(I,e)}function v(){if(!v.called){v.called=!0;var e=document.querySelectorAll("pre code");E.forEach.call(e,d)}}function m(){addEventListener("DOMContentLoaded",v,!1),addEventListener("load",v,!1)}function N(n,t){var r=L[n]=t(e);r.aliases&&r.aliases.forEach(function(e){y[e]=n})}function R(){return x(L)}function w(e){return e=(e||"").toLowerCase(),L[e]||L[y[e]]}var E=[],x=Object.keys,L={},y={},k=/^(no-?highlight|plain|text)$/i,B=/\blang(?:uage)?-([\w-]+)\b/i,M=/((^(<[^>]+>|\t|)+|(?:\n)))/gm,C="</span>",I={classPrefix:"hljs-",tabReplace:null,useBR:!1,languages:void 0};return e.highlight=f,e.highlightAuto=g,e.fixMarkup=p,e.highlightBlock=d,e.configure=b,e.initHighlighting=v,e.initHighlightingOnLoad=m,e.registerLanguage=N,e.listLanguages=R,e.getLanguage=w,e.inherit=o,e.IR="[a-zA-Z]\\w*",e.UIR="[a-zA-Z_]\\w*",e.NR="\\b\\d+(\\.\\d+)?",e.CNR="(-?)(\\b0[xX][a-fA-F0-9]+|(\\b\\d+(\\.\\d*)?|\\.\\d+)([eE][-+]?\\d+)?)",e.BNR="\\b(0b[01]+)",e.RSR="!|!=|!==|%|%=|&|&&|&=|\\*|\\*=|\\+|\\+=|,|-|-=|/=|/|:|;|<<|<<=|<=|<|===|==|=|>>>=|>>=|>=|>>>|>>|>|\\?|\\[|\\{|\\(|\\^|\\^=|\\||\\|=|\\|\\||~",e.BE={b:"\\\\[\\s\\S]",r:0},e.ASM={cN:"string",b:"'",e:"'",i:"\\n",c:[e.BE]},e.QSM={cN:"string",b:'"',e:'"',i:"\\n",c:[e.BE]},e.PWM={b:/\b(a|an|the|are|I'm|isn't|don't|doesn't|won't|but|just|should|pretty|simply|enough|gonna|going|wtf|so|such|will|you|your|they|like|more)\b/},e.C=function(n,t,r){var a=e.inherit({cN:"comment",b:n,e:t,c:[]},r||{});return a.c.push(e.PWM),a.c.push({cN:"doctag",b:"(?:TODO|FIXME|NOTE|BUG|XXX):",r:0}),a},e.CLCM=e.C("//","$"),e.CBCM=e.C("/\\*","\\*/"),e.HCM=e.C("#","$"),e.NM={cN:"number",b:e.NR,r:0},e.CNM={cN:"number",b:e.CNR,r:0},e.BNM={cN
GitHub
Hmm did we miss out on this when moving the management of JS dependencies to yarn?
I think we need a custom process here, we skipped this cause it is fairly tricky given we build custom bundles per site setting.
Not sure maybe @pmusaraj has some ideas on how we can get it into yarn.
I will look into having yarn manage highlight.js along with the other libraries. We do have a highlightjs:update task, I think it’s just a question of having it use yarn instead of npm and running it within javascript:update instead of separately.
