DEV: Use AR enums in reviewables related code (PR #15330)
:construction: :construction: :construction:
GitHub
The title of this pull request changed from “WIP: DEV: Use AR enums in reviewables related code” to "DEV: Use AR enums in reviewables related code
Is there a way to avoid public_send? That’s asking for trouble :stuck_out_tongue:
Other than that use of #public_send, lgtm!
Well it allows to use the automatically defined scopes from AR and if the status isn’t a valid one for whatever reason it will break. #who_did is a protected method and is only used in two places (L36 and L40), we control the value of status, nothing inherits from QueuedPostSerializer so I guess the trouble should be quite contained :slightly_smiling_face: Wdyt?
If it’s used in just two places, with :approved and :rejected as args, I would consider inlining this method. But I guess I’m fine with it as is too. :slightly_smiling_face:
Oh, or a half-way inlining solution would work too, e.g.
def approved_by_id
  scope.approved.last&.created_by_id
def rejected_by_id
  scope.rejected.last&.created_by_id
protected
# not necessarily the best name 😉
def scope
  object.
    reviewable_histories.
    transitioned.
    order(:created_at)
Ah yes this hybrid solution seems nice enough :ok_hand: I’m going to update the PR accordingly :slightly_smiling_face:
Updated! I wasn’t that inspired either and went with #post_history for the name.
Pushing this to 2.9
