DEV: Use filesystem-based SchemaCache in development (#12901)
In development we regularly restart/reload Rails, which wipes out the schema cache. This then has to be regenerated using DDL queries on the database.
Instead, we can make use of the rake db:schema:cache:dump command. This will dump the schema cache to a YAML file, and then load it when needed. This is significantly faster than rebuilding the cache from DDL queries every time.
diff --git a/.gitignore b/.gitignore
index c5cda59..5de911e 100644
--- a/.gitignore
+++ b/.gitignore
@@ -36,6 +36,7 @@ config/discourse.conf
 /db/*.sqlite3
 /db/structure.sql
 /db/schema.rb
+/db/schema_cache.yml
 # Ignore all logfiles and tempfiles.
 /log/*.log
diff --git a/config/application.rb b/config/application.rb
index f29044b..65e2a72 100644
--- a/config/application.rb
+++ b/config/application.rb
@@ -235,6 +235,9 @@ module Discourse
     # see: http://stackoverflow.com/questions/11894180/how-does-one-correctly-add-custom-sql-dml-in-migrations/11894420#11894420
     config.active_record.schema_format = :sql
+    # We use this in development-mode only (see development.rb)
+    config.active_record.use_schema_cache_dump = false
     # per https://www.owasp.org/index.php/Password_Storage_Cheat_Sheet
     config.pbkdf2_iterations = 64000
     config.pbkdf2_algorithm = "sha256"
diff --git a/config/environments/development.rb b/config/environments/development.rb
index 8d9ffb6..0c7810d 100644
--- a/config/environments/development.rb
+++ b/config/environments/development.rb
@@ -12,6 +12,9 @@ Discourse::Application.configure do
   # Log error messages when you accidentally call methods on nil.
   config.eager_load = false
+  # Use the schema_cache.yml file generated during db:migrate (via db:schema:cache:dump)
+  config.active_record.use_schema_cache_dump = true
   # Show full error reports and disable caching
   config.consider_all_requests_local       = true
   config.action_controller.perform_caching = false
diff --git a/lib/tasks/db.rake b/lib/tasks/db.rake
index 3575cc3..51929b8 100644
--- a/lib/tasks/db.rake
+++ b/lib/tasks/db.rake
@@ -221,6 +221,10 @@ task 'db:migrate' => ['load_config', 'environment', 'set_locale'] do |_, args|
   SeedFu.quiet = true
   SeedFu.seed(SeedHelper.paths, SeedHelper.filter)
+  if Rails.env.development?
+    Rake::Task['db:schema:cache:dump'].invoke
+  end
   if !Discourse.skip_post_deployment_migrations? && ENV['SKIP_OPTIMIZE_ICONS'] != '1'
     SiteIconManager.ensure_optimized!
GitHub sha: ad8c7714
This commit appears in #12901 which was approved by eviltrout. It was merged by davidtaylorhq.
