DEV: Use parallel-compatible formatter for logging autospec failures
The old method would cause the parallel processes to overwrite each other. The parallel formatter allows multiple processes to write to the same file.
diff --git a/lib/autospec/formatter.rb b/lib/autospec/formatter.rb
index a5fe09a..1ecd3c8 100644
--- a/lib/autospec/formatter.rb
+++ b/lib/autospec/formatter.rb
@@ -1,4 +1,5 @@
 require "rspec/core/formatters/base_text_formatter"
+require "parallel_tests/rspec/logger_base"
 module Autospec; end
@@ -43,3 +44,18 @@ class Autospec::Formatter < RSpec::Core::Formatters::BaseTextFormatter
+class Autospec::ParallelFormatter < ParallelTests::RSpec::LoggerBase
+  RSpec::Core::Formatters.register self, :example_failed
+  def message(*args);end
+  def dump_failures(*args);end
+  def dump_summary(*args);end
+  def dump_pending(*args);end
+  def seed(*args);end
+  def example_failed(notification)
+    output.puts notification.example.metadata[:location] + " "
+  end
+end
diff --git a/lib/autospec/simple_runner.rb b/lib/autospec/simple_runner.rb
index f060683..f8001b9 100644
--- a/lib/autospec/simple_runner.rb
+++ b/lib/autospec/simple_runner.rb
@@ -14,14 +14,18 @@ module Autospec
         self.abort
       # we use our custom rspec formatter
-      args = ["-r", "#{File.dirname(__FILE__)}/formatter.rb",
-        "-f", "Autospec::Formatter"]
+      args = ["-r", "#{File.dirname(__FILE__)}/formatter.rb"]
       command = begin
         if ENV["PARALLEL_SPEC"] &&
               !specs.split.any? { |s| puts s; s =~ /\:/ } # Parallel spec can't run specific groups
+          args += ["-f", "progress", "-f", "Autospec::ParallelFormatter", "-o", "./tmp/rspec_result"]
+          args += ["-f", "ParallelTests::RSpec::RuntimeLogger", "-o", "./tmp/parallel_runtime_rspec.log"] if specs == "spec"
           "parallel_rspec -- #{args.join(" ")} -- #{specs.split.join(" ")}"
         else
+          args += ["-f", "Autospec::Formatter"]
           "bin/rspec #{args.join(" ")} #{specs.split.join(" ")}"
GitHub sha: 02ed5e78
