DEV: Use `type` instead of `method` in ajax calls (PR #8974)
Even though type is an alias for method, we have custom logic in /discourse/lib/ajax that checks only type, and ~200 other ajax calls in the codebase already use type param.
GitHub
You’ve signed the CLA, CvX. Thank you! This pull request is ready for review.
:+1: Look safe, but maybe we should wait after release though? What if some things were relying on the fact that this check was not happening (probably unknowingly) ?
Can we also have a lint rule or similar to prevent us from using method when we should be using type?
I don’t know if they’re relying on it, but definitely using method had quite a few unintended consequences:
  1. It defaulted args.dataType to "json" for all requests instead of just GET
  2. It forced args.cache to true for on all requests instead of just GET (though I think jQ just ignores it for non-GET and non-HEAD calls)
  3. It didn’t update CSRF token when it was missing, before making the call (that’s the reason I had to update the tests: DEV: Use `type` instead of `method` in ajax calls by CvX · Pull Request #8974 · discourse/discourse · GitHub)
None of these are backbreaking (otherwise we would catch that earlier) but yeah, I’d wait with merging after the release. :wink:
I thought about it, but soon(-ish) we will most likely migrate to fetch (polyfilled or not) to drop the jQuery dependency, so a custom lint rule would be short-lived. (and fetch has has only one argument for this: method :wink:)
The other way to approach this would be to deprecate or soft-deprecate the old param:
if (args.method) {
  args.type = args.method;
  delete args.method;
What do you think?
Bump for @ZogStriP
Sure, that would work :+1:
@CvX any chances you could merge this sooner rather than later?
Can we use the deprecated helper here for consistency?
https://github.com/discourse/discourse/blob/7ec124fc897dced11eaf2e658011cb09b99f25e7/app/assets/javascripts/discourse-common/lib/deprecated.js.es6#L1
And also some short reason for the deprecation would be useful
Looks good, just a couple of small comments
Looks great :slight_smile:
