DEV: using Enter on a focused button should trigger action (#15564)
diff --git a/app/assets/javascripts/discourse/app/components/d-button.js b/app/assets/javascripts/discourse/app/components/d-button.js
index a584851..874d023 100644
--- a/app/assets/javascripts/discourse/app/components/d-button.js
+++ b/app/assets/javascripts/discourse/app/components/d-button.js
@@ -109,10 +109,24 @@ export default Component.extend({
     if (this.onKeyDown) {
       e.stopPropagation();
       this.onKeyDown(e);
+    } else if (e.key === "Enter") {
+      this._triggerAction(e);
+      return false;
   click(event) {
+    this._triggerAction(event);
+    return false;
+  mouseDown(event) {
+    if (this.preventFocus) {
+      event.preventDefault();
+  _triggerAction(event) {
     let { action } = this;
     if (action) {
@@ -141,13 +155,5 @@ export default Component.extend({
     event.stopPropagation();
-    return false;
-  mouseDown(event) {
-    if (this.preventFocus) {
-      event.preventDefault();
diff --git a/app/assets/javascripts/discourse/tests/integration/components/d-button-test.js b/app/assets/javascripts/discourse/tests/integration/components/d-button-test.js
index 2e02baf..9be51b3 100644
--- a/app/assets/javascripts/discourse/tests/integration/components/d-button-test.js
+++ b/app/assets/javascripts/discourse/tests/integration/components/d-button-test.js
@@ -7,6 +7,7 @@ import {
   query,
   queryAll,
 } from "discourse/tests/helpers/qunit-helpers";
+import { triggerKeyEvent } from "@ember/test-helpers";
 import I18n from "I18n";
 import hbs from "htmlbars-inline-precompile";
@@ -219,4 +220,49 @@ discourseModule("Integration | Component | d-button", function (hooks) {
+  componentTest("onKeyDown callback", {
+    template: hbs`{{d-button action=action onKeyDown=onKeyDown}}`,
+    beforeEach() {
+      this.set("foo", null);
+      this.set("onKeyDown", () => {
+        this.set("foo", "bar");
+      this.set("action", () => {
+        this.set("foo", "baz");
+    async test(assert) {
+      await triggerKeyEvent(".btn", "keydown", 32);
+      assert.strictEqual(this.foo, "bar");
+      await triggerKeyEvent(".btn", "keydown", 13);
+  componentTest("press Enter", {
+    template: hbs`{{d-button action=action}}`,
+    beforeEach() {
+      assert.strictEqual(this.foo, null);
GitHub sha: 25722e0b08717f94801315ebed5fcdd003d28fba
This commit appears in #15564 which was approved by CvX. It was merged by jjaffeux.
