DEV: Validity of distributed mutex configurable once per instance.
Follow up to 4f9e5e19c879273c4aeec125501809e8fe8b09c2.
diff --git a/lib/distributed_mutex.rb b/lib/distributed_mutex.rb
index ea3ca48..0dc4b86 100644
--- a/lib/distributed_mutex.rb
+++ b/lib/distributed_mutex.rb
@@ -3,24 +3,29 @@ class DistributedMutex
   DEFAULT_VALIDITY = 60
   def self.synchronize(key, redis: nil, validity: DEFAULT_VALIDITY, &blk)
-    self.new(key, redis).synchronize(validity: DEFAULT_VALIDITY, &blk)
+    self.new(
+      key,
+      redis: redis,
+      validity: validity
+    ).synchronize(&blk)
-  def initialize(key, redis = nil)
+  def initialize(key, redis: nil, validity: DEFAULT_VALIDITY)
     @key = key
     @using_global_redis = true if !redis
     @redis = redis || $redis
     @mutex = Mutex.new
+    @validity = validity
   CHECK_READONLY_ATTEMPT ||= 10
   # NOTE wrapped in mutex to maintain its semantics
-  def synchronize(validity: DEFAULT_VALIDITY)
+  def synchronize
     @mutex.lock
     attempts = 0
-    while !try_to_get_lock(validity)
+    while !try_to_get_lock
       sleep 0.001
       # in readonly we will never be able to get a lock
       if @using_global_redis && Discourse.recently_readonly?
@@ -41,11 +46,11 @@ class DistributedMutex
   private
-  def try_to_get_lock(validity)
+  def try_to_get_lock
     got_lock = false
-    if @redis.setnx @key, Time.now.to_i + validity
-      @redis.expire @key, validity
+    if @redis.setnx @key, Time.now.to_i + @validity
+      @redis.expire @key, @validity
       got_lock = true
     else
       begin
@@ -54,7 +59,7 @@ class DistributedMutex
         if time && time.to_i < Time.now.to_i
           got_lock = @redis.multi do
-            @redis.set @key, Time.now.to_i + validity
+            @redis.set @key, Time.now.to_i + @validity
       ensure
diff --git a/spec/components/distributed_mutex_spec.rb b/spec/components/distributed_mutex_spec.rb
index 09f0028..66a2cb5 100644
--- a/spec/components/distributed_mutex_spec.rb
+++ b/spec/components/distributed_mutex_spec.rb
@@ -44,13 +44,15 @@ describe DistributedMutex do
   it 'allows the validity of the lock to be configured' do
     freeze_time
-    mutex = DistributedMutex.new(key)
+    mutex = DistributedMutex.new(key, validity: 2)
-    mutex.synchronize(validity: 2) do
+    mutex.synchronize do
       expect($redis.ttl(key)).to eq(2)
       expect($redis.get(key).to_i).to eq(Time.now.to_i + 2)
+    mutex = DistributedMutex.new(key)
       expect($redis.ttl(key)).to eq(DistributedMutex::DEFAULT_VALIDITY)
GitHub sha: 4d31b425
