DEV: Yarn-manage moment and moment-timezone libraries
diff --git a/.eslintignore b/.eslintignore
index 54bd9d4..1806ae7 100644
--- a/.eslintignore
+++ b/.eslintignore
@@ -6,9 +6,6 @@ app/assets/javascripts/ember-addons/
 app/assets/javascripts/discourse/lib/autosize.js.es6
 lib/javascripts/locale/
 lib/javascripts/messageformat.js
-lib/javascripts/moment.js
-lib/javascripts/moment-timezone-with-data.js
-lib/javascripts/moment_locale/
 lib/highlight_js/
 plugins/**/lib/javascripts/locale
 public/javascripts/
diff --git a/lib/discourse_plugin_registry.rb b/lib/discourse_plugin_registry.rb
index f7db213..ab0db1a 100644
--- a/lib/discourse_plugin_registry.rb
+++ b/lib/discourse_plugin_registry.rb
@@ -204,8 +204,8 @@ class DiscoursePluginRegistry
   VENDORED_CORE_PRETTY_TEXT_MAP = {
-    "moment.js" => "lib/javascripts/moment.js",
-    "moment-timezone.js" => "lib/javascripts/moment-timezone-with-data.js"
+    "moment.js" => "vendor/assets/javascripts/moment.js",
+    "moment-timezone.js" => "vendor/assets/javascripts/moment-timezone-with-data.js"
   def self.core_asset_for_name(name)
     asset = VENDORED_CORE_PRETTY_TEXT_MAP[name]
diff --git a/lib/javascripts/moment-timezone-with-data.js b/lib/javascripts/moment-timezone-with-data.js
deleted file mode 100644
index f0c870d..0000000
--- a/lib/javascripts/moment-timezone-with-data.js
+++ /dev/null
@@ -1,1204 +0,0 @@
-//! moment-timezone.js
-//! version : 0.5.14
-//! Copyright (c) JS Foundation and other contributors
-//! license : MIT
-//! github.com/moment/moment-timezone
-(function (root, factory) {
-	"use strict";
-	/*global define*/
-	if (typeof define === 'function' && define.amd) {
-		define(['moment'], factory);                 // AMD
-	} else if (typeof module === 'object' && module.exports) {
-		module.exports = factory(require('moment')); // Node
-	} else {
-		factory(root.moment);                        // Browser
-}(this, function (moment) {
-	"use strict";
-	// Do not load moment-timezone a second time.
-	// if (moment.tz !== undefined) {
-	// 	logError('Moment Timezone ' + moment.tz.version + ' was already loaded ' + (moment.tz.dataVersion ? 'with data from ' : 'without any data') + moment.tz.dataVersion);
-	// 	return moment;
-	var VERSION = "0.5.14",
-		zones = {},
-		links = {},
-		names = {},
-		guesses = {},
-		cachedGuess,
-		momentVersion = moment.version.split('.'),
-		major = +momentVersion[0],
-		minor = +momentVersion[1];
-	// Moment.js version check
-	if (major < 2 || (major === 2 && minor < 6)) {
-		logError('Moment Timezone requires Moment.js >= 2.6.0. You are using Moment.js ' + moment.version + '. See momentjs.com');
-		Unpacking
-	function charCodeToInt(charCode) {
-		if (charCode > 96) {
-			return charCode - 87;
-		} else if (charCode > 64) {
-			return charCode - 29;
-		return charCode - 48;
-	function unpackBase60(string) {
-		var i = 0,
-			parts = string.split('.'),
-			whole = parts[0],
-			fractional = parts[1] || '',
-			multiplier = 1,
-			num,
-			out = 0,
-			sign = 1;
-		// handle negative numbers
-		if (string.charCodeAt(0) === 45) {
-			i = 1;
-			sign = -1;
-		// handle digits before the decimal
-		for (i; i < whole.length; i++) {
-			num = charCodeToInt(whole.charCodeAt(i));
-			out = 60 * out + num;
-		// handle digits after the decimal
-		for (i = 0; i < fractional.length; i++) {
-			multiplier = multiplier / 60;
-			num = charCodeToInt(fractional.charCodeAt(i));
-			out += num * multiplier;
-		return out * sign;
-	function arrayToInt (array) {
-		for (var i = 0; i < array.length; i++) {
-			array[i] = unpackBase60(array[i]);
-	function intToUntil (array, length) {
-		for (var i = 0; i < length; i++) {
-			array[i] = Math.round((array[i - 1] || 0) + (array[i] * 60000)); // minutes to milliseconds
-		array[length - 1] = Infinity;
-	function mapIndices (source, indices) {
-		var out = [], i;
-		for (i = 0; i < indices.length; i++) {
-			out[i] = source[indices[i]];
-		return out;
-	function unpack (string) {
-		var data = string.split('|'),
-			offsets = data[2].split(' '),
-			indices = data[3].split(''),
-			untils  = data[4].split(' ');
-		arrayToInt(offsets);
-		arrayToInt(indices);
-		arrayToInt(untils);
-		intToUntil(untils, indices.length);
-		return {
-			name       : data[0],
-			abbrs      : mapIndices(data[1].split(' '), indices),
-			offsets    : mapIndices(offsets, indices),
-			untils     : untils,
-			population : data[5] | 0
-		Zone object
-	function Zone (packedString) {
-		if (packedString) {
-			this._set(unpack(packedString));
-	Zone.prototype = {
-		_set : function (unpacked) {
-			this.name       = unpacked.name;
-			this.abbrs      = unpacked.abbrs;
-			this.untils     = unpacked.untils;
-			this.offsets    = unpacked.offsets;
-			this.population = unpacked.population;
-		_index : function (timestamp) {
-			var target = +timestamp,
-				untils = this.untils,
-				i;
-			for (i = 0; i < untils.length; i++) {
-				if (target < untils[i]) {
-					return i;
-		parse : function (timestamp) {
-				offsets = this.offsets,
-				max     = untils.length - 1,
-				offset, offsetNext, offsetPrev, i;
-			for (i = 0; i < max; i++) {
-				offset     = offsets[i];
-				offsetNext = offsets[i + 1];
-				offsetPrev = offsets[i ? i - 1 : i];
-				if (offset < offsetNext && tz.moveAmbiguousForward) {
-					offset = offsetNext;
-				} else if (offset > offsetPrev && tz.moveInvalidForward) {
-					offset = offsetPrev;
-				if (target < untils[i] - (offset * 60000)) {
-					return offsets[i];
-			return offsets[max];
-		abbr : function (mom) {
-			return this.abbrs[this._index(mom)];
-		offset : function (mom) {
-			logError("zone.offset has been deprecated in favor of zone.utcOffset");
-			return this.offsets[this._index(mom)];
-		utcOffset : function (mom) {
-		Current Timezone
-	function OffsetAt(at) {
-		var timeString = at.toTimeString();
-		var abbr = timeString.match(/\([a-z ]+\)/i);
-		if (abbr && abbr[0]) {
-			// 17:56:31 GMT-0600 (CST)
-			// 17:56:31 GMT-0600 (Central Standard Time)
-			abbr = abbr[0].match(/[A-Z]/g);
-			abbr = abbr ? abbr.join('') : undefined;
-		} else {
-			// 17:56:31 CST
-			// 17:56:31 GMT+0800 (台北標準時間)
-			abbr = timeString.match(/[A-Z]{3,5}/g);
-			abbr = abbr ? abbr[0] : undefined;
-		if (abbr === 'GMT') {
-			abbr = undefined;
-		this.at = +at;
-		this.abbr = abbr;
-		this.offset = at.getTimezoneOffset();
-	function ZoneScore(zone) {
-		this.zone = zone;
-		this.offsetScore = 0;
-		this.abbrScore = 0;
-	ZoneScore.prototype.scoreOffsetAt = function (offsetAt) {
-		this.offsetScore += Math.abs(this.zone.utcOffset(offsetAt.at) - offsetAt.offset);
-		if (this.zone.abbr(offsetAt.at).replace(/[^A-Z]/g, '') !== offsetAt.abbr) {
-			this.abbrScore++;
-	function findChange(low, high) {
-		var mid, diff;
-		while ((diff = ((high.at - low.at) / 12e4 | 0) * 6e4)) {
-			mid = new OffsetAt(new Date(low.at + diff));
-			if (mid.offset === low.offset) {
-				low = mid;
-			} else {
-				high = mid;
-		return low;
-	function userOffsets() {
-		var startYear = new Date().getFullYear() - 2,
-			last = new OffsetAt(new Date(startYear, 0, 1)),
-			offsets = [last],
-			change, next, i;
-		for (i = 1; i < 48; i++) {
-			next = new OffsetAt(new Date(startYear, i, 1));
-			if (next.offset !== last.offset) {
-				change = findChange(last, next);
-				offsets.push(change);
-				offsets.push(new OffsetAt(new Date(change.at + 6e4)));
-			last = next;
-		for (i = 0; i < 4; i++) {
GitHub sha: 5cef5b34
