discourse/discourse moved from master to main
diff --git a/README.md b/README.md
index be05ba8..fc6ca29 100644
--- a/README.md
+++ b/README.md
@@ -10,7 +10,7 @@
 The simplest way to get started is via the **standalone** template, which can be installed in 30 minutes or less. For detailed install instructions, see
-https://github.com/discourse/discourse/blob/master/docs/INSTALL-cloud.md
+https://github.com/discourse/discourse/blob/main/docs/INSTALL-cloud.md
 ### Directory Structure
diff --git a/image/README.md b/image/README.md
index 007f1f3..d291588 100644
--- a/image/README.md
+++ b/image/README.md
@@ -21,7 +21,7 @@ All of the dependencies for running Discourse.  This includes runit, postgres, n
 ### discourse_dev ([discourse/discourse_dev](https://hub.docker.com/r/discourse/discourse_dev/))
-Adds redis and postgres just like the "standalone" template for Discourse in order to have an all-in-one container for development.  Note that you are expected to mount your local discourse source directory to `/src`.  See [the README in GitHub's discourse/bin/docker](https://github.com/discourse/discourse/tree/master/bin/docker/) for utilities that help with this.
+Adds redis and postgres just like the "standalone" template for Discourse in order to have an all-in-one container for development.  Note that you are expected to mount your local discourse source directory to `/src`.  See [the README in GitHub's discourse/bin/docker](https://github.com/discourse/discourse/tree/main/bin/docker/) for utilities that help with this.
 Note that the discourse user is granted "sudo" permission without asking for a password in the discourse_dev image.  This is to facilitate the command-line Docker tools in discourse proper that run commands as the discourse user.
diff --git a/templates/web.template.yml b/templates/web.template.yml
index 83b84b2..04d1652 100644
--- a/templates/web.template.yml
+++ b/templates/web.template.yml
@@ -88,7 +88,7 @@ run:
       cmd:
         - git reset --hard
         - git clean -f
-        - git remote set-branches --add origin master
+        - git remote set-branches --add origin main
         - git remote set-branches origin $version
         - git fetch --depth 1 origin $version
         - git checkout $version
GitHub sha: e60174cfa035d591b7bd36c34c7abe8581e9a56b
This commit appears in #550 which was approved by pmusaraj. It was merged by Falco.
