Do not re-register items in inject-discourse-objects (PR #10025)
It appears that this breaks some test assumptions in some of our plugins when qunit is hitting category routes.
This might be an issue with the plugin, but the warnings/errors point here. Adding the following allows the tests to pass.
GitHub
This is a weird fix - why would the objects be registered twice? Can you trace it and figure out why that is happening? I would much prefer to fix that.
Oh hm, looks like the test failures were due to some earlier loading issues in this particular plugin, and doesn’t have anything to do in core. Resulting failures were red herrings - apologies for the noise!
