DOC: add section about fork safety
diff --git a/README.md b/README.md
index e0dc6cf..1760946 100644
--- a/README.md
+++ b/README.md
@@ -97,6 +97,27 @@ context.eval('bar()', filename: 'a/bar.js')
+### Fork safety
+Some Ruby web servers employ forking (for example unicorn or puma in clustered mode). V8 is not fork safe.
+Sadly Ruby does not have support for fork notifications per [#5446](https://bugs.ruby-lang.org/issues/5446).
+If you want to ensure your application does not leak memory after fork either:
+1. Ensure no MiniRacer::Context objects are created in the master process
+Or
+2. Dispose manually of all MiniRacer::Context objects prior to forking
+`‍``ruby
+# before fork
+require 'objspace'
+ObjectSpace.each_object(MiniRacer::Context){|c| c.dispose}
+# fork here
 ### Threadsafe
GitHub sha: f407f68b
