docker: remove -maxdepth from find
As far as I can recall, my original intent was to perform a recursive directory entry removal without resorting to a shell glob. Recursive descent works a lot better when find is allowed to, y’know, descend.
Suspect this was a brain fart on my part.
diff --git a/Dockerfile b/Dockerfile
index 906cde1..89522c2 100644
--- a/Dockerfile
+++ b/Dockerfile
@@ -20,9 +20,9 @@ RUN DEBIAN_FRONTEND=noninteractive apt-get update \
 		linux-libc-dev \
 	&& DEBIAN_FRONTEND=noninteractive apt-get -y --purge autoremove \
 	&& DEBIAN_FRONTEND=noninteractive apt-get clean \
-	&& ( find /var/lib/apt/lists -mindepth 1 -maxdepth 1 -delete || true ) \
-	&& ( find /var/tmp -mindepth 1 -maxdepth 1 -delete || true ) \
-	&& ( find /tmp -mindepth 1 -maxdepth 1 -delete || true )
+	&& ( find /var/lib/apt/lists -mindepth 1 -delete || true ) \
+	&& ( find /var/tmp -mindepth 1 -delete || true ) \
+	&& ( find /tmp -mindepth 1 -delete || true )
 ARG GIT_REVISION=invalid-build
 ENV MOBYSTASH_GIT_REVISION=$GIT_REVISION
GitHub sha: 5ea281cccad2cb61c99a7c9ba5700924f6e728be
