docker: update to 2.6-alpine
diff --git a/Dockerfile b/Dockerfile
index d6acd67..2287b33 100644
--- a/Dockerfile
+++ b/Dockerfile
@@ -1,4 +1,4 @@
-FROM ruby:2.3-alpine
+FROM ruby:2.6-alpine
 MAINTAINER Matt Palmer "matt.palmer@discourse.org"
@@ -12,7 +12,10 @@ RUN adduser -D ddnssd \
 	&& apk add build-base \
 	&& apk add postgresql-dev \
 	&& cd /home/ddnssd \
-	&& su -pc 'bundle install --deployment --without development' ddnssd \
+	&& su -pc 'gem install bundler:2.1.2' ddnssd \
+	&& su -pc 'bundle config set without development' ddnssd \
+	&& su -pc 'bundle config set deployment true' ddnssd \
+	&& su -pc 'bundle install' ddnssd \
 	&& apk del build-base \
 	&& rm -rf /tmp/* /var/cache/apk/*
@@ -20,7 +23,7 @@ ARG GIT_REVISION=invalid-build
 ENV DDNSSD_GIT_REVISION=$GIT_REVISION DDNSSD_DISABLE_LOG_TIMESTAMPS=yes
 COPY bin/* /usr/local/bin/
-COPY lib/ /usr/local/lib/ruby/2.3.0/
+COPY lib/ /usr/local/lib/ruby/2.6.0/
 EXPOSE 9218
 LABEL org.discourse.service._prom-exp.port=9218 org.discourse.service._prom-exp.instance=ddns-sd
diff --git a/Rakefile b/Rakefile
index 2da8f5a..70bcc22 100644
--- a/Rakefile
+++ b/Rakefile
@@ -36,7 +36,7 @@ end
 namespace :docker do
   desc "Build a new docker image"
   task :build do
-    sh "docker pull ruby:2.3-alpine"
+    sh "docker pull ruby:2.6-alpine"
     sh "docker build -t discourse/ddns-sd --build-arg=http_proxy=#{ENV['http_proxy']} --build-arg=GIT_REVISION=$(git rev-parse HEAD) ."
GitHub sha: 06a3f670
