DOCS: Add list of metrics series to readme (#116)
  • Add a list of metrics collected by ActiveRecord integration
  • Fix missing whitespace
  • Add a list of metrics collected by Process instrumentation
  • Add a list of metrics collected by Sidekiq instrumentation
  • Add a list of metrics collected by Shoryuken instrumentation
  • Add a list of metrics collected by Delayed Job instrumentation
  • Add a list of metrics collected by Hutch instrumentation
  • Add a list of metrics collected by Puma instrumentation
  • Add a list of metrics collected by Unicorn instrumentation
  • Add a list of metrics collected by Rails middleware
diff --git a/README.md b/README.md
index bcbd2b2..84f2c51 100644
--- a/README.md
+++ b/README.md
@@ -190,6 +190,23 @@ Ensure you run the exporter in a monitored background process:
 $ bundle exec prometheus_exporter
+#### Metrics collected by Rails integration middleware
+| Type    | Name                            | Description                                                 |
+| Counter | `http_requests_total`           | Total HTTP requests from web app                            |
+| Summary | `http_duration_seconds`         | Time spent in HTTP reqs in seconds                          |
+| Summary | `http_redis_duration_seconds`¹  | Time spent in HTTP reqs in Redis, in seconds                |
+| Summary | `http_sql_duration_seconds`²    | Time spent in HTTP reqs in SQL in seconds                   |
+| Summary | `http_queue_duration_seconds`³  | Time spent queueing the request in load balancer in seconds |
+All metrics have a `controller` and an `action` label.
+`http_requests_total` additionally has a (HTTP response) `status` label.
+¹) Only available when Redis is used.
+²) Only available when Mysql or PostgreSQL are used.
+³) Only available when [Instrumenting Request Queueing Time](#instrumenting-request-queueing-time) is set up.
 #### Activerecord Connection Pool Metrics
 This collects activerecord connection pool metrics.
@@ -244,6 +261,19 @@ Sidekiq.configure_server do |config|
+##### Metrics collected by ActiveRecord Instrumentation
+| Gauge | `active_record_connection_pool_connections` | Total connections in pool             |
+| Gauge | `active_record_connection_pool_busy`        | Connections in use in pool            |
+| Gauge | `active_record_connection_pool_dead`        | Dead connections in pool              |
+| Gauge | `active_record_connection_pool_idle`        | Idle connections in pool              |
+| Gauge | `active_record_connection_pool_waiting`     | Connection requests waiting           |
+| Gauge | `active_record_connection_pool_size`        | Maximum allowed connection pool size  |
+All metrics collected by the ActiveRecord integration include at least the following labels: `pid` (of the process the stats where collected in), `pool_name`, any labels included in the `config_labels` option (prefixed with `dbconfig_`, example: `dbconfig_host`), and all custom labels provided with the `custom_labels` option.
 #### Per-process stats
 You may also be interested in per-process stats. This collects memory and GC stats:
@@ -260,11 +290,30 @@ end
 # in unicorn/puma/passenger be sure to run a new process instrumenter after fork
 after_fork do
   require 'prometheus_exporter/instrumentation'
-  PrometheusExporter::Instrumentation::Process.start(type:"web")
+  PrometheusExporter::Instrumentation::Process.start(type: "web")
+##### Metrics collected by Process Instrumentation
+| Gauge   | `heap_free_slots`         | Free ruby heap slots                         |
+| Gauge   | `heap_live_slots`         | Used ruby heap slots                         |
+| Gauge   | `v8_heap_size`*           | Total JavaScript V8 heap size (bytes)        |
+| Gauge   | `v8_used_heap_size`*      | Total used JavaScript V8 heap size (bytes)   |
+| Gauge   | `v8_physical_size`*       | Physical size consumed by V8 heaps           |
+| Gauge   | `v8_heap_count`*          | Number of V8 contexts running                |
+| Gauge   | `rss`                     | Total RSS used by process                    |
+| Counter | `major_gc_ops_total`      | Major GC operations by process               |
+| Counter | `minor_gc_ops_total`      | Minor GC operations by process               |
+| Counter | `allocated_objects_total` | Total number of allocated objects by process |
+_Metrics marked with * are only collected when `MiniRacer` is defined._
+Metrics collected by Process instrumentation include labels `type` (as given with the `type` option), `pid` (of the process the stats where collected in), and any custom labels given to `Process.start` with the `labels` option.
 #### Sidekiq metrics
 Including Sidekiq metrics (how many jobs ran? how many failed? how long did they take? how many are dead? how many were restarted?)
@@ -311,6 +360,35 @@ Sometimes the Sidekiq server shuts down before it can send metrics, that were ge
+##### Metrics collected by Sidekiq Instrumentation
+**PrometheusExporter::Instrumentation::Sidekiq**
+| Counter | `sidekiq_job_duration_seconds` | Total time spent in sidekiq jobs                                             |
+| Counter | `sidekiq_jobs_total`           | Total number of sidekiq jobs executed                                        |
+| Counter | `sidekiq_restarted_jobs_total` | Total number of sidekiq jobs that we restarted because of a sidekiq shutdown |
+| Counter | `sidekiq_failed_jobs_total`    | Total number of failed sidekiq jobs                                          |
+All metrics have a `job_name` label.
+**PrometheusExporter::Instrumentation::Sidekiq.death_handler**
+| Counter | `sidekiq_dead_jobs_total` | Total number of dead sidekiq jobs |
+This metric also has a `job_name` label.
+**PrometheusExporter::Instrumentation::SidekiqQueue**
+| Gauge | `sidekiq_queue_backlog_total`   | Size of the sidekiq queue    |
+| Gauge | `sidekiq_queue_latency_seconds` | Latency of the sidekiq queue |
+Both metrics will have a `queue` label with the name of the queue.
+_See [Metrics collected by Process Instrumentation](#metrics-collected-by-process-instrumentation) for a list of metrics the Process instrumentation will produce._
 #### Shoryuken metrics
 For Shoryuken metrics (how many jobs ran? how many failed? how long did they take? how many were restarted?)
@@ -324,6 +402,17 @@ Shoryuken.configure_server do |config|
+##### Metrics collected by Shoryuken Instrumentation
+| Counter | `shoryuken_job_duration_seconds` | Total time spent in shoryuken jobs                                               |
+| Counter | `shoryuken_jobs_total`           | Total number of shoryuken jobs executed                                          |
+| Counter | `shoryuken_restarted_jobs_total` | Total number of shoryuken jobs that we restarted because of a shoryuken shutdown |
+| Counter | `shoryuken_failed_jobs_total`    | Total number of failed shoryuken jobs                                            |
+All metrics have labels for `job_name` and `queue_name`.
 #### Delayed Job plugin
 In an initializer:
@@ -335,6 +424,19 @@ unless Rails.env == "test"
+##### Metrics collected by Delayed Job Instrumentation
GitHub sha: a799454a
This commit appears in #116 which was merged by SamSaffron.
