DOCS: improve developer guide (#27)
diff --git a/README.md b/README.md
index 7a1db3f..4842360 100644
--- a/README.md
+++ b/README.md
@@ -194,6 +194,24 @@ MiniSql is designed to be very minimal. Even though the query builder and type m
 ## Development
 To install this gem onto your local machine, run `bundle exec rake install`. To release a new version, update the version number in `version.rb`, and then run `bundle exec rake release`, which will create a git tag for the version, push git commits and tags, and push the `.gem` file to [rubygems.org](https://rubygems.org).
+### Local testing
+`‍``bash
+  docker run --name mini-sql-mysql --rm -it -p 33306:3306 -e MYSQL_DATABASE=test_mini_sql -e MYSQL_ALLOW_EMPTY_PASSWORD=yes -d mysql:5.7
+  export MINI_SQL_MYSQL_HOST=127.0.0.1
+  export MINI_SQL_MYSQL_PORT=33306
+  docker run --name mini-sql-postgres --rm -it -p 55432:5432 -e POSTGRES_DB=test_mini_sql -e POSTGRES_HOST_AUTH_METHOD=trust -d postgres
+  export MINI_SQL_PG_USER=postgres
+  export MINI_SQL_PG_HOST=127.0.0.1
+  export MINI_SQL_PG_PORT=55432
+  sleep 10 # waiting for up databases
+  bundle exec rake
+  # end working on mini-sql
+  docker stop mini-sql-postgres mini-sql-mysql
 ## Contributing
diff --git a/test/test_helper.rb b/test/test_helper.rb
index c5aa0f2..3bc446c 100644
--- a/test/test_helper.rb
+++ b/test/test_helper.rb
@@ -36,7 +36,13 @@ else
   def pg_connection(options = {})
-    pg_conn = PG.connect(dbname: 'test_mini_sql')
+    args = { dbname: 'test_mini_sql' }
+    %i[port host password user].each do |name|
+      if val = ENV["MINI_SQL_PG_#{name.upcase}"]
+        args[name] = val
+      end
+    end
+    pg_conn = PG.connect(args)
     MiniSql::Connection.get(pg_conn, options)
GitHub sha: ab4c5fdf
This commit appears in #27 which was merged by SamSaffron.
