DOCS: Update min versions (#12932)
Update the minimum required version for ruby, pg, and redis to match what is listed in the INSTALL.md file.
diff --git a/README.md b/README.md
index 9b78068..15bbce6 100644
--- a/README.md
+++ b/README.md
@@ -35,7 +35,7 @@ To get your environment setup, follow the community setup guide for your operati
 If you're familiar with how Rails works and are comfortable setting up your own environment, you can also try out the [**Discourse Advanced Developer Guide**](docs/DEVELOPER-ADVANCED.md), which is aimed primarily at Ubuntu and macOS environments.
-Before you get started, ensure you have the following minimum versions: [Ruby 2.6+](https://www.ruby-lang.org/en/downloads/), [PostgreSQL 10+](https://www.postgresql.org/download/), [Redis 4.0+](https://redis.io/download). If you're having trouble, please see our [**TROUBLESHOOTING GUIDE**](docs/TROUBLESHOOTING.md) first!
+Before you get started, ensure you have the following minimum versions: [Ruby 2.7+](https://www.ruby-lang.org/en/downloads/), [PostgreSQL 13+](https://www.postgresql.org/download/), [Redis 6.0+](https://redis.io/download). If you're having trouble, please see our [**TROUBLESHOOTING GUIDE**](docs/TROUBLESHOOTING.md) first!
 ## Setting up Discourse
GitHub sha: 174c6850
This commit appears in #12932 which was approved by ZogStriP. It was merged by blake.
