FEAT: Allow image resize by width or height
|150x resizes to 150px wide + auto-height. x150 resizes to 150px tall and auto-width.
Resize value can be from 1 to 999 (incl. for percentages).
diff --git a/app/assets/javascripts/pretty-text/engines/discourse-markdown-it.js.es6 b/app/assets/javascripts/pretty-text/engines/discourse-markdown-it.js.es6
index 5a77beb..9708f5a 100644
--- a/app/assets/javascripts/pretty-text/engines/discourse-markdown-it.js.es6
+++ b/app/assets/javascripts/pretty-text/engines/discourse-markdown-it.js.es6
@@ -122,7 +122,7 @@ function setupHoister(md) {
   md.renderer.rules.html_raw = renderHoisted;
-const IMG_SIZE_REGEX = /^([1-9]+[0-9]*)x([1-9]+[0-9]*)(\s*,\s*([1-9][0-9]?)%)?$/;
+const IMG_SIZE_REGEX = /^([1-9]+[0-9]*)x([1-9]+[0-9]*)(\s*,\s*(x?)([1-9][0-9]{0,2}?)([%x]?))?$/;
 function renderImage(tokens, idx, options, env, slf) {
   var token = tokens[idx];
@@ -140,12 +140,27 @@ function renderImage(tokens, idx, options, env, slf) {
         let width = match[1];
         let height = match[2];
-        if (match[4]) {
-          let percent = parseFloat(match[4]) / 100.0;
+        // calculate using percentage
+        if (match[5] && match[6] && match[6] === "%") {
+          let percent = parseFloat(match[5]) / 100.0;
           width = parseInt(width * percent);
           height = parseInt(height * percent);
+        // calculate using only given width
+        if (match[5] && match[6] && match[6] === "x") {
+          let wr = parseFloat(match[5]) / width;
+          width = parseInt(match[5]);
+          height = parseInt(height * wr);
+        // calculate using only given height
+        if (match[5] && match[4] && match[4] === "x" && !match[6]) {
+          let hr = parseFloat(match[5]) / height;
+          height = parseInt(match[5]);
+          width = parseInt(width * hr);
         if (token.attrIndex("width") === -1) {
           token.attrs.push(["width", width]);
diff --git a/spec/components/pretty_text_spec.rb b/spec/components/pretty_text_spec.rb
index 1490e38..6088a7d 100644
--- a/spec/components/pretty_text_spec.rb
+++ b/spec/components/pretty_text_spec.rb
@@ -1228,16 +1228,20 @@ HTML
       expect(cooked).to eq(html.strip)
-    it "allows whitespace before the percent scaler" do
+    it "ignores whitespace and allows scaling by percent, width, height" do
       cooked = PrettyText.cook <<~MD
         ![|220x100, 50%](http://png.com/my.png)
         ![|220x100 , 50%](http://png.com/my.png)
         ![|220x100 ,50%](http://png.com/my.png)
+        ![|220x100,150x](http://png.com/my.png)
+        ![|220x100, x50](http://png.com/my.png)
       MD
       html = <<~HTML
         <p><img src="http://png.com/my.png" alt width="110" height="50"><br>
+        <img src="http://png.com/my.png" alt width="110" height="50"><br>
+        <img src="http://png.com/my.png" alt width="150" height="68"><br>
         <img src="http://png.com/my.png" alt width="110" height="50"></p>
       HTML
GitHub sha: 2a007baf
