FEATURE: A low priority filter for the review queue. (#12822)
This filter hides reviewables with a score lower than the “reviewable_low_priority_threshold” setting. We only use reviewables that already met this threshold to calculate the Medium and High priority filters.
diff --git a/app/assets/javascripts/discourse/app/controllers/review-index.js b/app/assets/javascripts/discourse/app/controllers/review-index.js
index dc28bf6..73f2c65 100644
--- a/app/assets/javascripts/discourse/app/controllers/review-index.js
+++ b/app/assets/javascripts/discourse/app/controllers/review-index.js
@@ -49,7 +49,7 @@ export default Controller.extend({
   @discourseComputed
   priorities() {
-    return ["low", "medium", "high"].map((priority) => {
+    return ["any", "low", "medium", "high"].map((priority) => {
       return {
diff --git a/app/jobs/scheduled/reviewable_priorities.rb b/app/jobs/scheduled/reviewable_priorities.rb
index 7e0f5bb..cb74ead 100644
--- a/app/jobs/scheduled/reviewable_priorities.rb
+++ b/app/jobs/scheduled/reviewable_priorities.rb
@@ -16,13 +16,16 @@ class Jobs::ReviewablePriorities < ::Jobs::Scheduled
   def execute(args)
     return unless Reviewable.where('score > 0').count >= self.class.min_reviewables
-    res = DB.query_single(<<~SQL, target_count: self.class.target_count)
+    min_priority_threshold = SiteSetting.reviewable_low_priority_threshold
+    res = DB.query_single(<<~SQL, target_count: self.class.target_count, min_priority: min_priority_threshold)
       SELECT COALESCE(PERCENTILE_DISC(0.5) WITHIN GROUP (ORDER BY score), 0.0) AS medium,
         COALESCE(PERCENTILE_DISC(0.85) WITHIN GROUP (ORDER BY score), 0.0) AS high
       FROM (
         SELECT r.score
         FROM reviewables AS r
         INNER JOIN reviewable_scores AS rs ON rs.reviewable_id = r.id
+        WHERE r.score >= :min_priority
         GROUP BY r.id
         HAVING COUNT(*) >= :target_count
       ) AS x
@@ -32,6 +35,10 @@ class Jobs::ReviewablePriorities < ::Jobs::Scheduled
     medium, high = res
-    Reviewable.set_priorities(medium: medium, high: high)
+    Reviewable.set_priorities(
+      low: min_priority_threshold,
+      medium: medium,
+      high: high
diff --git a/app/models/reviewable.rb b/app/models/reviewable.rb
index cb96447..9b729bd 100644
--- a/app/models/reviewable.rb
+++ b/app/models/reviewable.rb
@@ -444,8 +444,6 @@ class Reviewable < ActiveRecord::Base
     to_date: nil,
     additional_filters: {}
-    min_score = Reviewable.min_score_for_priority(priority)
     order = case sort_order
             when 'score_asc'
               'reviewables.score ASC, reviewables.created_at DESC'
@@ -488,6 +486,8 @@ class Reviewable < ActiveRecord::Base
+    min_score = Reviewable.min_score_for_priority(priority)
     if min_score > 0 && status == :pending
       result = result.where("reviewables.score >= ? OR reviewables.force_review", min_score)
     elsif min_score > 0
diff --git a/config/initializers/014-track-setting-changes.rb b/config/initializers/014-track-setting-changes.rb
index fed99a6..1340d1d 100644
--- a/config/initializers/014-track-setting-changes.rb
+++ b/config/initializers/014-track-setting-changes.rb
@@ -48,4 +48,9 @@ DiscourseEvent.on(:site_setting_changed) do |name, old_value, new_value|
   if SiteSetting::WATCHED_SETTINGS.include?(name)
     SiteSetting.reset_cached_settings!
+  # Make sure medium and high priority thresholds were calculated.
+  if name == :reviewable_low_priority_threshold && Reviewable.min_score_for_priority(:medium) > 0
+    Reviewable.set_priorities(low: new_value)
+  end
diff --git a/config/locales/client.en.yml b/config/locales/client.en.yml
index 0cf26e8..40213e1 100644
--- a/config/locales/client.en.yml
+++ b/config/locales/client.en.yml
@@ -516,7 +516,8 @@ en:
         priority:
           title: "Minimum Priority"
-          low: "(any)"
+          any: "(any)"
+          low: "Low"
           medium: "Medium"
           high: "High"
diff --git a/config/locales/server.en.yml b/config/locales/server.en.yml
index a054513..66589a8 100644
--- a/config/locales/server.en.yml
+++ b/config/locales/server.en.yml
@@ -1956,6 +1956,7 @@ en:
     reviewable_claiming: "Does reviewable content need to be claimed before it can be acted upon?"
     reviewable_default_topics: "Show reviewable content grouped by topic by default"
     reviewable_default_visibility: "Don't show reviewable items unless they meet this priority"
+    reviewable_low_priority_threshold: "The priority filter hides reviewable that doesn't meet this score unless the '(any)' filter is used."
     high_trust_flaggers_auto_hide_posts: "New user posts are automatically hidden after being flagged as spam by a TL3+ user"
     cooldown_hours_until_reflag: "How much time users will have to wait until they are able to reflag a post"
diff --git a/config/site_settings.yml b/config/site_settings.yml
index 5464916..beacd3a 100644
--- a/config/site_settings.yml
+++ b/config/site_settings.yml
@@ -1710,6 +1710,10 @@ spam:
     type: enum
     default: low
     enum: "ReviewablePrioritySetting"
+    default: 1
+    min: 1
 rate_limits:
   unique_posts_mins: 5
diff --git a/spec/initializers/track_setting_changes_spec.rb b/spec/initializers/track_setting_changes_spec.rb
index 82b7963..b6e86c1 100644
--- a/spec/initializers/track_setting_changes_spec.rb
+++ b/spec/initializers/track_setting_changes_spec.rb
@@ -22,4 +22,27 @@ describe 'Setting changes' do
       expect(non_approved_user.reload.approved?).to eq(true)
+  describe '#reviewable_low_priority_threshold' do
+    let(:new_threshold) { 5 }
+    it 'sets the low priority value' do
+      medium_threshold = 10
+      Reviewable.set_priorities(medium: medium_threshold)
+      expect(Reviewable.min_score_for_priority(:low)).not_to eq(new_threshold)
+      SiteSetting.reviewable_low_priority_threshold = new_threshold
+      expect(Reviewable.min_score_for_priority(:low)).to eq(new_threshold)
+    end
+    it "does nothing if the other thresholds were not calculated" do
+      Reviewable.set_priorities(medium: 0.0)
+    end
+  end
diff --git a/spec/jobs/reviewable_priorities_spec.rb b/spec/jobs/reviewable_priorities_spec.rb
index 2227637..9a5c96d 100644
--- a/spec/jobs/reviewable_priorities_spec.rb
+++ b/spec/jobs/reviewable_priorities_spec.rb
@@ -6,42 +6,65 @@ describe Jobs::ReviewablePriorities do
   it "needs returns 0s with no existing reviewables" do
     Jobs::ReviewablePriorities.new.execute({})
-    expect(Reviewable.min_score_for_priority(:low)).to eq(0.0)
-    expect(Reviewable.min_score_for_priority(:medium)).to eq(0.0)
-    expect(Reviewable.min_score_for_priority(:high)).to eq(0.0)
+    expect_min_score(:low, 0.0)
+    expect_min_score(:medium, 0.0)
+    expect_min_score(:high, 0.0)
     expect(Reviewable.score_required_to_hide_post).to eq(8.33)
-  fab!(:u0) { Fabricate(:user) }
-  fab!(:u1) { Fabricate(:user) }
+  fab!(:user_0) { Fabricate(:user) }
+  fab!(:user_1) { Fabricate(:user) }
   def create_reviewables(count)
-    (1..count).each do |i|
-      r = Fabricate(:reviewable_flagged_post)
-      r.add_score(u0, PostActionType.types[:off_topic])
-      r.add_score(u1, PostActionType.types[:off_topic])
-      r.update!(score: i)
+    (1..count).each { |i| create_with_score(i) }
+  end
+  def create_with_score(score)
+    Fabricate(:reviewable_flagged_post).tap do |reviewable|
+      reviewable.add_score(user_0, PostActionType.types[:off_topic])
+      reviewable.add_score(user_1, PostActionType.types[:off_topic])
+      reviewable.update!(score: score)
   it "needs a minimum amount of reviewables before it calculates anything" do
     create_reviewables(5)
GitHub sha: 60059a71
This commit appears in #12822 which was approved by eviltrout. It was merged by romanrizzi.
