FEATURE: add APIS for unpausing all sites
This adjusts 53d592ad by @tgxworld
  • Adds Sidekiq.upause_all! to unpause all sites
  • Adds Sidekiq.paused_dbs to list dbs that are currently paused
  • Handles some edge cases where unpause thread could extend expiry on sites that were unpaused from a different process
  • Ensures tests always terminates background thread used for pause keepalive
diff --git a/lib/sidekiq/pausable.rb b/lib/sidekiq/pausable.rb
index 16d4a71..4810647 100644
--- a/lib/sidekiq/pausable.rb
+++ b/lib/sidekiq/pausable.rb
@@ -14,7 +14,6 @@ class SidekiqPauser
     @mutex.synchronize do
       extend_lease_thread
-      sleep 0.001 while !paused?
     true
@@ -24,10 +23,29 @@ class SidekiqPauser
     !!$redis.get(PAUSED_KEY)
+  def unpause_all!
+    @mutex.synchronize do
+      @dbs = Set.new
+      stop_extend_lease_thread
+    end
+    RailsMultisite::ConnectionManagement.each_connection do
+      unpause! if paused?
+    end
+  end
+  def paused_dbs
+    dbs = []
+      dbs << RailsMultisite::ConnectionManagement.current_db if paused?
+    end
+    dbs
+  end
   def unpause!
       @dbs.delete(RailsMultisite::ConnectionManagement.current_db)
-      @extend_lease_thread = nil if @dbs.size == 0
+      stop_extend_lease_thread if @dbs.size == 0
     $redis.del(PAUSED_KEY)
@@ -36,16 +54,32 @@ class SidekiqPauser
   private
+  def stop_extend_lease_thread
+    # should always be called from a mutex
+    if t = @extend_lease_thread
+      @extend_lease_thread = nil
+      while t.alive?
+        t.wakeup
+        sleep 0
+      end
+    end
+  end
   def extend_lease_thread
     @dbs << RailsMultisite::ConnectionManagement.current_db
     @extend_lease_thread ||= Thread.new do
       while true do
-        break unless @mutex.synchronize { @extend_lease_thread }
+        break if !@extend_lease_thread
         @dbs.each do |db|
           RailsMultisite::ConnectionManagement.with_connection(db) do
-            $redis.expire PAUSED_KEY, TTL
+            if !$redis.expire(PAUSED_KEY, TTL)
+              # if it was unpaused in another process we got to remove the
+              # bad key
+              @dbs.delete(db)
+            end
@@ -68,6 +102,14 @@ module Sidekiq
   def self.unpause!
     @pauser.unpause!
+  def self.unpause_all!
+    @pauser.unpause_all!
+  end
+  def self.paused_dbs
+    @pauser.paused_dbs
+  end
 # server middleware that will reschedule work whenever Sidekiq is paused
diff --git a/spec/multisite/pausable_spec.rb b/spec/multisite/pausable_spec.rb
index 57297dd..dc0e0f9 100644
--- a/spec/multisite/pausable_spec.rb
+++ b/spec/multisite/pausable_spec.rb
@@ -2,9 +2,6 @@ require 'rails_helper'
 require_dependency 'sidekiq/pausable'
 RSpec.describe "Pausing/Unpausing Sidekiq", type: :multisite do
-  after do
-    $redis.flushall
-  end
   describe '#pause!, #unpause! and #paused?' do
     it "can pause and unpause" do
@@ -23,13 +20,21 @@ RSpec.describe "Pausing/Unpausing Sidekiq", type: :multisite do
         Sidekiq.pause!
         expect(Sidekiq.paused?).to eq(true)
+      expect(Sidekiq.paused_dbs).to eq(["second"])
+      Sidekiq.unpause_all!
+        expect(Sidekiq.paused?).to eq(false)
+      end
 RSpec.describe Sidekiq::Pausable do
   after do
-    $redis.flushall
   it "can still run heartbeats when paused" do
GitHub sha: 74d2d4f6
