FEATURE: add backup directory for mmdb files
This new DISCOURSE_MAXMIND_BACKUP_PATH can be used a secondary location for maxmind db. That way a build machine, for example can cache it on the host and reuse between builds.
Also per 5bfeef77 added proper error raising for download fails from dedicated rake task
This also moves “refresh_maxmind_db_during_precompile_days” to a global setting, it did not make sense in a site setting
diff --git a/config/discourse_defaults.conf b/config/discourse_defaults.conf
index 784d395..60bb0ec 100644
--- a/config/discourse_defaults.conf
+++ b/config/discourse_defaults.conf
@@ -208,3 +208,10 @@ max_old_rebakes_per_15_minutes = 300
 # maximum number of log messages in /logs
 max_logster_logs = 1000
+# during precompile update maxmind database if older than N days
+# set to 0 to disable
+refresh_maxmind_db_during_precompile_days = 2
+# backup path containing maxmind db files
+maxmind_backup_path =
diff --git a/config/site_settings.yml b/config/site_settings.yml
index a1b4a08..aefa536 100644
--- a/config/site_settings.yml
+++ b/config/site_settings.yml
@@ -1534,12 +1534,6 @@ developer:
   enable_safe_mode:
     default: true
     client: true
-  refresh_maxmind_db_during_precompile_days:
-    min: 0
-    max: 120
-    default: 2
-    hidden: true
-    shadowed_by_global: true
 embedding:
   feed_polling_enabled:
diff --git a/lib/discourse_ip_info.rb b/lib/discourse_ip_info.rb
index 0af821e..37b0fa2 100644
--- a/lib/discourse_ip_info.rb
+++ b/lib/discourse_ip_info.rb
@@ -27,20 +27,16 @@ class DiscourseIpInfo
   def self.mmdb_download(name)
     FileUtils.mkdir_p(path)
-    begin
-      gz_file = FileHelper.download(
-        "https://geolite.maxmind.com/geoip/databases/#{name}/update",
-        max_file_size: 100.megabytes,
-        tmp_file_name: "#{name}.gz"
-      Discourse::Utils.execute_command("gunzip", gz_file.path)
-      path = gz_file.path.sub(/\.gz\z/, "")
-      FileUtils.mv(path, mmdb_path(name))
-    rescue OpenURI::HTTPError => e
-      Rails.logger.warn("MaxMindDB (#{name}) could not be downloaded: #{e}")
-    end
+    gz_file = FileHelper.download(
+      "https://geolite.maxmind.com/geoip/databases/#{name}/update",
+      max_file_size: 100.megabytes,
+      tmp_file_name: "#{name}.gz"
+    Discourse::Utils.execute_command("gunzip", gz_file.path)
+    path = gz_file.path.sub(/\.gz\z/, "")
+    FileUtils.mv(path, mmdb_path(name))
   ensure
     gz_file&.close!
diff --git a/lib/tasks/assets.rake b/lib/tasks/assets.rake
index 9fe3a48..dca6e6d 100644
--- a/lib/tasks/assets.rake
+++ b/lib/tasks/assets.rake
@@ -158,15 +158,75 @@ def concurrent?
+def get_mmdb_time(root_path)
+  mmdb_time = nil
+  %w{
+    GeoLite2-City
+    GeoLite2-ASN
+  }.map do |name|
+    path = File.join(root_path, "#{name}.mmdb")
+    if File.exist?(path)
+      mmdb_time = File.mtime(path)
+    else
+      mmdb_time = nil
+      break
+    end
+  end
+  mmdb_time
+end
+def copy_maxmind(from_path, to_path)
+  puts "Copying MaxMindDB from #{from_path} to #{to_path}"
+  %w{
+    GeoLite2-City
+    GeoLite2-ASN
+  }.each do |name|
+    from = File.join(from_path, "#{name}.mmdb")
+    to = File.join(to_path, "#{name}.mmdb")
+    FileUtils.cp(from, to, preserve: true)
+  end
+end
 task 'assets:precompile' => 'assets:precompile:before' do
-  if refresh_days = SiteSetting.refresh_maxmind_db_during_precompile_days
-    mmdb_path = DiscourseIpInfo.mmdb_path('GeoLite2-City')
-    mmdb_time = File.exist?(mmdb_path) && File.mtime(mmdb_path)
+  refresh_days = GlobalSetting.refresh_maxmind_db_during_precompile_days
+  if refresh_days.to_i > 0
+    mmdb_time = get_mmdb_time(DiscourseIpInfo.path)
+    backup_mmdb_time =
+      if GlobalSetting.maxmind_backup_path.present?
+        get_mmdb_time(GlobalSetting.maxmind_backup_path)
+      end
+    mmdb_time ||= backup_mmdb_time
+    if backup_mmdb_time && backup_mmdb_time >= mmdb_time
+      copy_maxmind(GlobalSetting.maxmind_backup_path, DiscourseIpInfo.path)
+    end
     if !mmdb_time || mmdb_time < refresh_days.days.ago
       puts "Downloading MaxMindDB..."
       mmdb_thread = Thread.new do
-        DiscourseIpInfo.mmdb_download('GeoLite2-City')
-        DiscourseIpInfo.mmdb_download('GeoLite2-ASN')
+        begin
+          DiscourseIpInfo.mmdb_download('GeoLite2-City')
+          DiscourseIpInfo.mmdb_download('GeoLite2-ASN')
+            copy_maxmind(DiscourseIpInfo.path, GlobalSetting.maxmind_backup_path)
+          end
+        rescue OpenURI::HTTPError => e
+          STDERR.puts("*" * 100)
+          STDERR.puts("MaxMindDB (#{name}) could not be downloaded: #{e}")
+          Rails.logger.warn("MaxMindDB (#{name}) could not be downloaded: #{e}")
+        end
GitHub sha: 6580025a
Should we also add a migration to remove that value from the database?
Shouldn’t that be an each instead of a map?
Why not return nil here instead?
We might want to extract these names as they’re being re-used quite often.
DEV: clean up backup maxmind path
OK followed up.
Not a huge fan of returning from a block, I find it confusing. Especially since lambda / block is slightly different in that department.
Regarding migration, I think we can skip this for now, it was there for such a short time and there is also no way of migration the site setting to a global anyway.
