FEATURE: add class to <aside> quote block when quoting an ignored user (PR #9511)
Adds the class ‘ignored-user’ to the
Per Tiny feature request for core: add 3 classes - dev - Discourse Meta
GitHub
This pull request has been mentioned on Discourse Meta. There might be relevant details there:
https://meta.discourse.org/t/tiny-feature-request-for-core-add-3-classes/148725/6
No idea why some tests are failing. As you can see, my submission is exactly one line of code, with spaces instead of tabs, etc. :man_shrugging:t2:
The title of this pull request changed from “FEATURE: add class to
It looks like the failures are linting related. Can you use double quotes instead of single quotes?
Thanks!
Thank YOU!
