FEATURE: Add global admin api key rate limiter (PR #12527)
GitHub
as in borderline a way of abusing api limits is creating enormous amounts of keys?
If so I guess then we want this global limit to be higher than the per key limit, otherwise makes less sense to keep the key limit?
I am good with this change, merge at will. Be sure to check our local repos for usage of old key.
