FEATURE: Add `./launcher run` command.
FEATURE: Add ./launcher run command.
This is useful for running custom commands
with the config for a given template.
From 1ec142a14a08aa352ea869d17939e15ee53283b7 Mon Sep 17 00:00:00 2001
Date: Tue, 18 Sep 2018 17:06:20 +0800
Subject: [PATCH] FEATURE: Add `./launcher run` command.
diff --git a/launcher b/launcher
index ae41c18..5b5d5dc 100755
--- a/launcher
+++ b/launcher
@@ -3,15 +3,16 @@
 usage () {
   echo "Usage: launcher COMMAND CONFIG [--skip-prereqs] [--docker-args STRING]"
   echo "Commands:"
-  echo "    start:      Start/initialize a container"
-  echo "    stop:       Stop a running container"
-  echo "    restart:    Restart a container"
-  echo "    destroy:    Stop and remove a container"
-  echo "    enter:      Open a shell to run commands inside the container"
-  echo "    logs:       View the Docker logs for a container"
-  echo "    bootstrap:  Bootstrap a container for the config based on a template"
-  echo "    rebuild:    Rebuild a container (destroy old, bootstrap, start new)"
-  echo "    cleanup:    Remove all containers that have stopped for > 24 hours"
+  echo "    start:       Start/initialize a container"
+  echo "    stop:        Stop a running container"
+  echo "    restart:     Restart a container"
+  echo "    destroy:     Stop and remove a container"
+  echo "    enter:       Open a shell to run commands inside the container"
+  echo "    logs:        View the Docker logs for a container"
+  echo "    bootstrap:   Bootstrap a container for the config based on a template"
+  echo "    run:         Run the given command with the config for the given template."
+  echo "    rebuild:     Rebuild a container (destroy old, bootstrap, start new)"
+  echo "    cleanup:     Remove all containers that have stopped for > 24 hours"
   echo
   echo "Options:"
   echo "    --skip-prereqs             Don't check launcher prerequisites"
@@ -24,6 +25,10 @@ command=$1
 config=$2
 user_args=""
+if [[ $command == "run" ]]; then
+  run_command=$3
+fi
 while [ ${#} -gt 0 ]; do
   case "${1}" in
   --debug)
@@ -561,10 +566,7 @@ run_start() {
-run_bootstrap() {
-  # I got no frigging clue what this does, ask Sam Saffron. It RUNS STUFF ON THE HOST I GUESS?
+setup_bootstrap() {
   host_run
   # Is the image available?
@@ -585,7 +587,17 @@ run_bootstrap() {
   set_volumes
   set_links
+run_run() {
+  setup_bootstrap
+  $docker_path run --rm --shm-size=512m $user_args $links "${env[@]}" -e DOCKER_HOST_IP="$docker_ip" -i -a stdin -a stdout -a stderr $volumes $image \
+    /bin/bash -c "$run_command"
+run_bootstrap() {
+  setup_bootstrap
   rm -f $cidbootstrap
   run_command="cd /pups &&"
@@ -637,6 +649,11 @@ case "$command" in
       exit 0
+  run)
+      run_run
+      exit 0
   enter)
       exec $docker_path exec -it $config /bin/bash --login
GitHub
:heart: thanks for figuring it
