FEATURE: add rake task that resets ACL on every object in S3
Some previous migrations to S3 may have bad ACLs set on objects. This introduces a new rake task (rake s3:correct_acl) that will reset ACL on every S3 object.
Vast majority of users will never have to run it, but if you have ACL issues this is the atomic solution.
diff --git a/lib/tasks/s3.rake b/lib/tasks/s3.rake
index 356ca55..58d12e1 100644
--- a/lib/tasks/s3.rake
+++ b/lib/tasks/s3.rake
@@ -101,6 +101,36 @@ def ensure_s3_configured!
+task 's3:correct_acl' => :environment do
+  ensure_s3_configured!
+  puts "ensuring public-read is set on every upload and optimized image"
+  i = 0
+  base_url = Discourse.store.absolute_base_url
+  objects = Upload.pluck(:id, :url).map { |array| array << :upload }
+  objects.concat(OptimizedImage.pluck(:id, :url).map { |array| array << :optimized_image })
+  puts "#{objects.length} objects found"
+  objects.each do |id, url, type|
+    i += 1
+    if !url.start_with?(base_url)
+      puts "Skipping #{type} #{id} since it is not stored on s3, url is #{url}"
+    else
+      key = url[(base_url.length + 1)..-1]
+      object = Discourse.store.s3_helper.object(key)
+      object.acl.put(acl: "public-read")
+    end
+    if i % 100 == 0
+      puts "#{i} done"
+    end
+  end
+end
 task 's3:upload_assets' => :environment do
GitHub sha: 05a3e367
