FEATURE: Add rake task to check old posts (#23)
Add rake akismet:scan_old task that can be used to scan the first post of users who never had a post scanned by akismet.
diff --git a/lib/tasks/akismet.rake b/lib/tasks/akismet.rake
new file mode 100644
index 0000000..cca5ec1
--- /dev/null
+++ b/lib/tasks/akismet.rake
@@ -0,0 +1,70 @@
+desc 'Checks old posts using Akismet'
+task 'akismet:scan_old' => :environment do
+  # Scan the first post of users that match:
+  # - regular posts only
+  # - not deleted posts
+  # - post contains a URL
+  # - user is not trusted (TL0-2 and not staff)
+  # - no other post of this user was checked before
+  sql = <<~SQL
+    WITH first_user_posts AS (
+      SELECT MIN(posts.id) post_id, posts.user_id
+      FROM posts
+      JOIN topics on topics.id = posts.topic_id
+      WHERE (raw LIKE '%http%' OR cooked LIKE '%href%')
+        AND archetype = 'regular'
+        AND posts.deleted_at IS NULL
+        AND topics.deleted_at IS NULL
+      GROUP BY posts.user_id
+    SELECT user_id, post_id
+    FROM first_user_posts
+    JOIN users u on u.id = first_user_posts.user_id
+    WHERE NOT EXISTS (SELECT 1
+                      FROM post_custom_fields c
+                      JOIN posts ON posts.id = c.post_id
+                      WHERE posts.user_id = first_user_posts.user_id
+                        AND name = 'AKISMET_STATE'
+                      ) -- no post from this user was checked or is scheduled
+      AND NOT admin
+      AND NOT moderator
+      AND trust_level < 3
+    ORDER BY post_id
+  SQL
+  post_ids = DB.query(sql)
+  puts "This task is going to check #{post_ids.size} posts"
+  exit if ENV['DRY_RUN'].present?
+  DiscourseAkismet::PostsBouncer.munge_args do |args|
+    args[:recheck_reason] = 'recheck_queue'
+  end
+  bouncer = DiscourseAkismet::PostsBouncer.new
+  client = Akismet::Client.build_client
+  spam_count = 0
+  not_spam_count = 0
+  post_ids.each do |row|
+    post = Post.find_by(id: row.post_id)
+    next if post.blank?
+    DistributedMutex.synchronize("akismet_post_#{post.id}") do
+      bouncer.move_to_state(post, 'new')
+      bouncer.perform_check(client, post)
+    end
+    if post.custom_fields[DiscourseAkismet::Bouncer::AKISMET_STATE] == 'confirmed_spam'
+      print 'X'
+      spam_count += 1
+    else
+      print '.'
+      not_spam_count += 1
+    end
+  end
+  puts "DONE! Found #{spam_count} / #{spam_count + not_spam_count} spam posts"
+end
GitHub sha: cbd9f1be
This commit appears in #23 which was approved by SamSaffron. It was merged by SamSaffron.
