FEATURE: Add setting to control the Expect header on S3 calls (PR #9591)
Some providers don’t implement the Expect: 100-continue support, which results in a mismatch in the object signature.
With this settings, users can disable the header and use such providers.
GitHub
The title of this pull request changed from “FEATURE: Add setting to controle the Expect header on S3 calls” to "FEATURE: Add setting to control the Expect header on S3 calls
This pull request has been mentioned on Discourse Meta. There might be relevant details there:
https://meta.discourse.org/t/using-object-storage-for-uploads-s3-clones/148916/26
