FEATURE: Add setting to controle the Expect header on S3 calls
Some providers don’t implement the Expect: 100-continue support, which results in a mismatch in the object signature.
With this settings, users can disable the header and use such providers.
diff --git a/config/discourse_defaults.conf b/config/discourse_defaults.conf
index 0a4eb66..4adfdca 100644
--- a/config/discourse_defaults.conf
+++ b/config/discourse_defaults.conf
@@ -196,6 +196,7 @@ s3_secret_access_key =
 s3_use_iam_profile =
 s3_cdn_url =
 s3_endpoint =
+s3_http_continue_timeout =
 ### rate limits apply to all sites
 max_user_api_reqs_per_minute = 20
diff --git a/config/site_settings.yml b/config/site_settings.yml
index 2a0733c..ef0fea4 100644
--- a/config/site_settings.yml
+++ b/config/site_settings.yml
@@ -1202,6 +1202,9 @@ files:
   s3_endpoint:
     default: ""
     regex: '^https?:\/\/.+[^\/]$'
+  s3_http_continue_timeout:
+    default: 1
+    hidden: true
   s3_cdn_url:
     default: ""
diff --git a/lib/s3_helper.rb b/lib/s3_helper.rb
index ccc0da3..ef3bc7d 100644
--- a/lib/s3_helper.rb
+++ b/lib/s3_helper.rb
@@ -204,6 +204,7 @@ class S3Helper
     opts[:endpoint] = SiteSetting.s3_endpoint if SiteSetting.s3_endpoint.present?
+    opts[:http_continue_timeout] = SiteSetting.s3_http_continue_timeout
     unless obj.s3_use_iam_profile
       opts[:access_key_id] = obj.s3_access_key_id
GitHub sha: 08e4af66
This commit appears in #9591 which was approved by eviltrout. It was merged by Falco.
