FEATURE: Add site setting to restrict ignore feature to trust level (#11297)
This adds a new min_trust_level_to_allow_ignore site setting that enables admins to control the point at which a user is allowed to ignore other users.
diff --git a/config/locales/server.en.yml b/config/locales/server.en.yml
index e753a04..fd52a18 100644
--- a/config/locales/server.en.yml
+++ b/config/locales/server.en.yml
@@ -1840,6 +1840,7 @@ en:
     min_trust_level_to_allow_profile_background: "The minimum trust level required to upload a profile background"
     min_trust_level_to_allow_user_card_background: "The minimum trust level required to upload a user card background"
     min_trust_level_to_allow_invite: "The minimum trust level required to invite users"
+    min_trust_level_to_allow_ignore: "The minimum trust level required to ignore users"
     allowed_link_domains: "Domains that users may link to even if they don't have the appropriate trust level to post links"
     newuser_max_links: "How many links a new user can add to a post."
diff --git a/config/site_settings.yml b/config/site_settings.yml
index 08f2083..192200d 100644
--- a/config/site_settings.yml
+++ b/config/site_settings.yml
@@ -1419,6 +1419,9 @@ trust:
     default: 2
     enum: "TrustLevelSetting"
+    default: 2
+    enum: "TrustLevelSetting"
   allow_flagging_staff: true
   send_tl1_welcome_message: true
   send_tl2_promotion_message: true
diff --git a/lib/guardian.rb b/lib/guardian.rb
index ef8319e..7f6935d 100644
--- a/lib/guardian.rb
+++ b/lib/guardian.rb
@@ -487,7 +487,7 @@ class Guardian
   def can_ignore_users?
     return false if anonymous?
-    @user.staff? || @user.trust_level >= TrustLevel.levels[:member]
+    @user.staff? || @user.has_trust_level?(SiteSetting.min_trust_level_to_allow_ignore.to_i)
   def allowed_theme_repo_import?(repo)
diff --git a/spec/components/guardian_spec.rb b/spec/components/guardian_spec.rb
index cf94a4b..e2a2a9b 100644
--- a/spec/components/guardian_spec.rb
+++ b/spec/components/guardian_spec.rb
@@ -2960,6 +2960,9 @@ describe Guardian do
   describe '#can_ignore_user?' do
+    before do
+      SiteSetting.min_trust_level_to_allow_ignore = 1
+    end
     let(:guardian) { Guardian.new(trust_level_2) }
@@ -2983,26 +2986,29 @@ describe Guardian do
-    context "when ignorer's trust level is below tl2" do
-      let(:guardian) { Guardian.new(trust_level_1) }
-      let!(:trust_level_1) { build(:user, trust_level: 1) }
+    context "when ignorer is staff" do
+      let(:guardian) { Guardian.new(admin) }
+      it 'allows ignoring user' do
+        expect(guardian.can_ignore_user?(another_user)).to eq(true)
+      end
+    end
+    context "when ignorer's trust level is below min_trust_level_to_allow_ignore" do
+      let(:guardian) { Guardian.new(trust_level_0) }
       it 'does not allow ignoring user' do
         expect(guardian.can_ignore_user?(another_user)).to eq(false)
-    context "when ignorer is staff" do
-      let(:guardian) { Guardian.new(admin) }
+    context "when ignorer's trust level is equal to min_trust_level_to_allow_ignore site setting" do
+      let(:guardian) { Guardian.new(trust_level_1) }
-    context "when ignorer's trust level is tl2" do
-      let(:guardian) { Guardian.new(trust_level_2) }
+    context "when ignorer's trust level is above min_trust_level_to_allow_ignore site setting" do
+      let(:guardian) { Guardian.new(trust_level_3) }
GitHub sha: 0ec62358
This commit appears in #11297 which was approved by ZogStriP. It was merged by tshenry.
