FEATURE: add suggested_topics_unread_max_days_old
This new site setting determines the maximum age of unread topics in suggested. By default if you have any unread topics older than 90 days they will be omitted from suggested.
This change was added for 2 reasons:
  1. A performance safeguard, some users tend to collect a huge amount of read state so it becomes super expensive to find unread
  2. People who collect a large amount of unread are much more interested in recent unread topics vs ancient unread topics, this makes suggested more relevant
Also, this is a minor speed up for tests cause 3 expensive tests became 1.
diff --git a/config/locales/server.en.yml b/config/locales/server.en.yml
index 530546f..332b4a6 100644
--- a/config/locales/server.en.yml
+++ b/config/locales/server.en.yml
@@ -1567,6 +1567,7 @@ en:
     suggested_topics: "Number of suggested topics shown at the bottom of a topic."
     limit_suggested_to_category: "Only show topics from the current category in suggested topics."
     suggested_topics_max_days_old: "Suggested topics should not be more than n days old."
+    suggested_topics_unread_max_days_old: "Suggested unread topics should not be more than n days old."
     clean_up_uploads: "Remove orphan unreferenced uploads to prevent illegal hosting. WARNING: you may want to back up of your /uploads directory before enabling this setting."
     clean_orphan_uploads_grace_period_hours: "Grace period (in hours) before an orphan upload is removed."
diff --git a/config/site_settings.yml b/config/site_settings.yml
index 0292517..3c45ced 100644
--- a/config/site_settings.yml
+++ b/config/site_settings.yml
@@ -141,6 +141,10 @@ basic:
     max: 2000
     default: false
+    default: 90
+    min: 0
+    max: 10000
     default: 365
     min: 7
diff --git a/lib/topic_query.rb b/lib/topic_query.rb
index 0a861a0..b004583 100644
--- a/lib/topic_query.rb
+++ b/lib/topic_query.rb
@@ -222,7 +222,15 @@ class TopicQuery
         )) unless builder.full?
       else
-        builder.add_results(unread_results(topic: topic, per_page: builder.results_left), :high)
+        builder.add_results(
+          unread_results(
+            topic: topic,
+            per_page: builder.results_left,
+            max_age: SiteSetting.suggested_topics_unread_max_days_old
+          ), :high
         builder.add_results(new_results(topic: topic, per_page: builder.category_results_left)) unless builder.full?
@@ -470,12 +478,17 @@ class TopicQuery
       .order('CASE WHEN topics.user_id = tu.user_id THEN 1 ELSE 2 END')
     if @user
       # micro optimisation so we don't load up all of user stats which we do not need
       unread_at = DB.query_single(
         "select first_unread_at from user_stats where user_id = ?",
         @user.id).first
+      if max_age = options[:max_age]
+        max_age_date = max_age.days.ago
+        unread_at ||= max_age_date
+        unread_at = unread_at > max_age_date ? unread_at : max_age_date
+      end
       # perf note, in the past we tried doing this in a subquery but performance was
       # terrible, also tried with a join and it was bad
       result = result.where("topics.updated_at >= ?", unread_at)
diff --git a/spec/components/topic_query_spec.rb b/spec/components/topic_query_spec.rb
index b1503b3..c41e87b 100644
--- a/spec/components/topic_query_spec.rb
+++ b/spec/components/topic_query_spec.rb
@@ -3,7 +3,12 @@ require 'topic_view'
 describe TopicQuery do
+  # TODO: this let! here has impact on all tests
+  #  it indeed happens first, but is not obvious later in the tests we depend on the user being
+  #  created so early otherwise finding new topics does not work
+  #  we should remove the let! here and use freeze time to communicate how the clock moves
   let!(:user) { Fabricate(:coding_horror) }
   let(:creator) { Fabricate(:user) }
   let(:topic_query) { TopicQuery.new(user) }
@@ -734,12 +739,16 @@ describe TopicQuery do
     context 'when logged in' do
+      def suggested_for(topic)
+        topic_query.list_suggested_for(topic).topics.map { |t| t.id }
+      end
       let(:topic) { Fabricate(:topic) }
       let(:suggested_topics) {
         tt = topic
         # lets clear cache once category is created - working around caching is hard
         clear_cache!
-        topic_query.list_suggested_for(tt).topics.map { |t| t.id }
+        suggested_for(tt)
       it "should return empty results when there is nothing to find" do
@@ -839,7 +848,19 @@ describe TopicQuery do
       context 'with some existing topics' do
-        let!(:partially_read) { Fabricate(:post, user: creator).topic }
+        let!(:old_partially_read) {
+          topic = Fabricate(:post, user: creator).topic
+          Fabricate(:post, user: creator, topic: topic)
+          topic
+        let!(:partially_read) {
+          topic
         let!(:new_topic) { Fabricate(:post, user: creator).topic }
         let!(:fully_read) { Fabricate(:post, user: creator).topic }
         let!(:closed_topic) { Fabricate(:topic, user: creator, closed: true) }
@@ -849,42 +870,49 @@ describe TopicQuery do
         let!(:fully_read_archived) { Fabricate(:post, user: creator).topic }
         before do
-          user.user_option.auto_track_topics_after_msecs = 0
-          user.user_option.save
-          TopicUser.update_last_read(user, partially_read.id, 0, 0, 0)
+          user.user_option.update!(
+            auto_track_topics_after_msecs: 0,
+            new_topic_duration_minutes: User::NewTopicDuration::ALWAYS
+          freeze_time 3.weeks.from_now
+          TopicUser.update_last_read(user, old_partially_read.id, 1, 1, 0)
+          TopicUser.update_last_read(user, partially_read.id, 1, 1, 0)
           TopicUser.update_last_read(user, fully_read.id, 1, 1, 0)
           TopicUser.update_last_read(user, fully_read_closed.id, 1, 1, 0)
           TopicUser.update_last_read(user, fully_read_archived.id, 1, 1, 0)
           fully_read_closed.closed = true
           fully_read_closed.save
           fully_read_archived.archived = true
           fully_read_archived.save
-        end
-        it "returns unread, then new, then random" do
-          SiteSetting.suggested_topics = 7
-          expect(suggested_topics[0]).to eq(partially_read.id)
-          expect(suggested_topics[1, 3]).to include(new_topic.id)
-          expect(suggested_topics[1, 3]).to include(closed_topic.id)
-          expect(suggested_topics[1, 3]).to include(archived_topic.id)
+          old_partially_read.update!(updated_at: 2.weeks.ago)
+          partially_read.update!(updated_at: Time.now)
-          # The line below appears to randomly fail, no idea why need to restructure test
-          #expect(suggested_topics[4]).to eq(fully_read.id)
-          # random doesn't include closed and archived
-        it "won't return new or fully read if there are enough partially read topics" do
-          SiteSetting.suggested_topics = 1
-          expect(suggested_topics).to eq([partially_read.id])
-        end
+        it "operates correctly" do
+          # Note, this is a pretty slow integration test
+          # it tests that suggested is returned in the expected order
+          # hence we run suggested_for twice here to save on all the setup
-        it "won't return fully read if there are enough partially read topics and new topics" do
           SiteSetting.suggested_topics = 4
+          SiteSetting.suggested_topics_unread_max_days_old = 7
+          expect(suggested_topics[1, 3]).to contain_exactly(new_topic.id, closed_topic.id, archived_topic.id)
+          expect(suggested_topics.length).to eq(4)
+          SiteSetting.suggested_topics = 2
+          SiteSetting.suggested_topics_unread_max_days_old = 15
+          expect(suggested_for(topic)).to contain_exactly(partially_read.id, old_partially_read.id)
GitHub sha: 0c35b8b4
