FEATURE: add support for plugin-pinning (#470)
  • FEATURE: add support for plugin-pinning
checks out pinned plugin versions, if defined, by way of the rake task
  • refactor rake task name
diff --git a/templates/web.template.yml b/templates/web.template.yml
index 826759f..e7ed111 100644
--- a/templates/web.template.yml
+++ b/templates/web.template.yml
@@ -151,6 +151,12 @@ run:
       hook: bundle_exec
       cmd:
         - su discourse -c 'bundle install --deployment --retry 3 --jobs 4 --verbose --without test development'
+  - exec:
+      cd: $home
+      cmd: bundle exec rake plugin:pull_compatible_all
+      raise_on_fail: false
   - exec:
       cd: $home
       hook: db_migrate
GitHub sha: 8026a344
This commit appears in #470 which was merged by featheredtoast.
