FEATURE: Add topic excerpt max length site setting (#9847)
Adds a new topic_excerpt_maxlength site setting.
  • When topic excerpt is requested for a post, use the new topic_excerpt_maxlength site setting to limit the size of the excerpt
  • Remove code for getting/setting Post.excerpt_size as it is not used anywhere
diff --git a/app/models/post.rb b/app/models/post.rb
index 89dbbcf..30ebaf0 100644
--- a/app/models/post.rb
+++ b/app/models/post.rb
@@ -159,14 +159,6 @@ class Post < ActiveRecord::Base
     includes(:post_details).find_by(post_details: { key: key, value: value })
-  def self.excerpt_size=(sz)
-    @excerpt_size = sz
-  end
-    @excerpt_size || 220
-  end
   def whisper?
     post_type == Post.types[:whisper]
@@ -482,7 +474,7 @@ class Post < ActiveRecord::Base
   def excerpt_for_topic
-    Post.excerpt(cooked, Post.excerpt_size, strip_links: true, strip_images: true, post: self)
+    Post.excerpt(cooked, SiteSetting.topic_excerpt_maxlength, strip_links: true, strip_images: true, post: self)
   def is_first_post?
diff --git a/config/locales/server.en.yml b/config/locales/server.en.yml
index 996fd40..d44d467 100644
--- a/config/locales/server.en.yml
+++ b/config/locales/server.en.yml
@@ -1467,6 +1467,7 @@ en:
     exclude_rel_nofollow_domains: "A list of domains where nofollow should not be added to links. example.com will automatically allow sub.example.com as well. As a minimum, you should add the domain of this site to help web crawlers find all content. If other parts of your website are at other domains, add those too."
     post_excerpt_maxlength: "Maximum length of a post excerpt / summary."
+    topic_excerpt_maxlength: "Maximum length of a topic excerpt / summary, generated from the first post in a topic."
     show_pinned_excerpt_mobile: "Show excerpt on pinned topics in mobile view."
     show_pinned_excerpt_desktop: "Show excerpt on pinned topics in desktop view."
     post_onebox_maxlength: "Maximum length of a oneboxed Discourse post in characters."
diff --git a/config/site_settings.yml b/config/site_settings.yml
index ea4bbd4..8838795 100644
--- a/config/site_settings.yml
+++ b/config/site_settings.yml
@@ -819,6 +819,12 @@ posting:
       ja: 120
       zh_CN: 120
       zh_TW: 120
+    default: 220
+    locale_default:
+      ja: 120
+      zh_CN: 120
+      zh_TW: 120
     client: true
     default: true
diff --git a/spec/components/search_spec.rb b/spec/components/search_spec.rb
index a455d81..599ea3c 100644
--- a/spec/components/search_spec.rb
+++ b/spec/components/search_spec.rb
@@ -444,7 +444,7 @@ describe Search do
       let(:expected_blurb) do
-        "...to satisfy any test conditions that require content longer than the typical test post raw content. elephant"
+        "...quire content longer than the typical test post raw content. It really is some long content, folks. elephant"
       it 'returns the post' do
diff --git a/spec/fabricators/post_fabricator.rb b/spec/fabricators/post_fabricator.rb
index 42235cb..77a234d 100644
--- a/spec/fabricators/post_fabricator.rb
+++ b/spec/fabricators/post_fabricator.rb
@@ -10,7 +10,7 @@ end
 Fabricator(:post_with_long_raw_content, from: :post) do
   raw 'This is a sample post with semi-long raw content. The raw content is also more than
       two hundred characters to satisfy any test conditions that require content longer
-      than the typical test post raw content.'
+      than the typical test post raw content. It really is some long content, folks.'
 Fabricator(:post_with_youtube, from: :post) do
diff --git a/spec/models/post_spec.rb b/spec/models/post_spec.rb
index 4cc716d..d0e2aba 100644
--- a/spec/models/post_spec.rb
+++ b/spec/models/post_spec.rb
@@ -1158,6 +1158,25 @@ describe Post do
     expect(post.custom_fields).to eq("Tommy" => "Hanks", "Vincent" => "Vega")
+  describe "#excerpt_for_topic" do
+    it "returns a topic excerpt, defaulting to 220 chars" do
+      expected_excerpt = "This is a sample post with semi-long raw content. The raw content is also more than \ntwo hundred characters to satisfy any test conditions that require content longer \nthan the typical test post raw content. It really is&hellip;"
+      post = Fabricate(:post_with_long_raw_content)
+      post.rebake!
+      excerpt = post.excerpt_for_topic
+      expect(excerpt).to eq(expected_excerpt)
+    end
+    it "respects the site setting for topic excerpt" do
+      SiteSetting.topic_excerpt_maxlength = 10
+      expected_excerpt = "This is a &hellip;"
+      post.rebake!
+    end
+  end
   describe "#rebake!" do
     it "will rebake a post correctly" do
       post = create_post
GitHub sha: df68d11c
This commit appears in #9847 which was merged by martin.
