FEATURE: Add uploads:batch_migrate_from_s3 task to limit total posts migrated at once (PR #9933)
Allow limiting the number of migrations to do at once, both to do migrations that have impact limited to multiple off-peak usage hours to reduce user impact from a migration, and to allow tests that do only a very small number for test purposes. (“Give me a ping, Vasili. One ping only, please.”)
GitHub
This pull request has been mentioned on Discourse Meta. There might be relevant details there:
https://meta.discourse.org/t/migrate-from-s3-problems/119064/3
LGTM :+1:
@martin-brennan can you review and merge if ok?
@johnsonm Looks great, thanks for adding those extra specs and cleaning up the exit codes. Extra points for The Hunt for Red October reference :100:
:tada: thanks both of you for the review!
