FEATURE: Adds a pop up that shows a more detailed score for reviewables (PR #8035)
If you click a (?) icon beside the reviewable status a pop up will appear with expanded informatio that explains how the reviewable got its score, and how it compares to system thresholds.
GitHub
You’ve signed the CLA, eviltrout. Thank you! This pull request is ready for review.
This pull request has been mentioned on Discourse Meta. There might be relevant details there:
this.setProperties({loading: true, reviewableExplanation: null});
.then(result => this.set("reviewableExplanation", result))
Thanks for the feedback @jjaffeux, I made both changes.
