* FEATURE: Adds site setting to let quotes on direct replies.
  • DEV: Added test.
  • FIX: Do not bump topic when removing full quotes.
* DEV: Added test.
* FIX: Do not bump topic when removing full quotes.
diff --git a/config/locales/server.en.yml b/config/locales/server.en.yml
index 53dbf49..44ea490 100644
--- a/config/locales/server.en.yml
+++ b/config/locales/server.en.yml
@@ -1308,6 +1308,7 @@ en:
     send_tl1_welcome_message: "Send new trust level 1 users a welcome message."
     suppress_reply_directly_below: "Don't show the expandable reply count on a post when there is only a single reply directly below this post."
     suppress_reply_directly_above: "Don't show the expandable in-reply-to on a post when there is only a single reply directly above this post."
+    remove_full_quote: "Automatically remove full quotes on direct replies."
     suppress_reply_when_quoting: "Don't show the expandable in-reply-to on a post when post quotes reply."
     max_reply_history: "Maximum number of replies to expand when expanding in-reply-to"
     topics_per_period_in_top_summary: "Number of top topics shown in the default top topics summary."
diff --git a/config/site_settings.yml b/config/site_settings.yml
index 9fb2571..ebb1930 100644
--- a/config/site_settings.yml
+++ b/config/site_settings.yml
@@ -675,6 +675,8 @@ posting:
     default: true
     default: true
+    default: true
   max_reply_history:
     default: 1
     client: true
diff --git a/lib/cooked_post_processor.rb b/lib/cooked_post_processor.rb
index 301ce31..9c9ed22 100644
--- a/lib/cooked_post_processor.rb
+++ b/lib/cooked_post_processor.rb
@@ -87,7 +87,7 @@ class CookedPostProcessor
   def removed_direct_reply_full_quotes
-    return if @post.post_number == 1
+    return if !SiteSetting.remove_full_quote || @post.post_number == 1
     num_quotes = @doc.css("aside.quote").size
     return if num_quotes != 1
@@ -104,7 +104,8 @@ class CookedPostProcessor
         raw: new_raw.strip,
         edit_reason: I18n.t(:removed_direct_reply_full_quotes)
-      skip_validations: true
+      skip_validations: true,
+      bypass_bump: true
diff --git a/spec/components/cooked_post_processor_spec.rb b/spec/components/cooked_post_processor_spec.rb
index 7decf8c..829a4e8 100644
--- a/spec/components/cooked_post_processor_spec.rb
+++ b/spec/components/cooked_post_processor_spec.rb
@@ -1146,28 +1146,44 @@ describe CookedPostProcessor do
   context "remove direct reply full quote" do
     let(:topic) { Fabricate(:topic) }
+    let!(:post) { Fabricate(:post, topic: topic, raw: "this is the first post") }
+    let(:raw) do
+      <<~RAW
+      [quote="#{post.user.username}, post:#{post.post_number}, topic:#{topic.id}"]
+      this is the first post
+      [/quote]
+      and this is the third reply
+      RAW
+    end
     it 'works' do
-      post = Fabricate(:post, topic: topic, raw: "this is the first post")
-      hidden = Fabricate(:post, topic: topic, hidden: true, raw: "this is the second post")
-      small_action = Fabricate(:post, topic: topic, post_type: Post.types[:small_action])
-      raw = <<~RAW
-        [quote="#{post.user.username}, post:#{post.post_number}, topic:#{topic.id}"]
-        this is the first post
-        [/quote]
+      SiteSetting.remove_full_quote = true
-        and this is the third reply
-      RAW
+      hidden = Fabricate(:post, topic: topic, hidden: true, raw: "this is the second post after")
+      small_action = Fabricate(:post, topic: topic, post_type: Post.types[:small_action])
       reply = Fabricate(:post, topic: topic, raw: raw)
-      cpp = CookedPostProcessor.new(reply)
-      cpp.removed_direct_reply_full_quotes
+      freeze_time Time.zone.now do
+        topic.bumped_at = 1.day.ago
+        CookedPostProcessor.new(reply).removed_direct_reply_full_quotes
+        expect(topic.posts).to eq([post, hidden, small_action, reply])
+        expect(topic.bumped_at).to eq(1.day.ago)
+        expect(reply.raw).to eq("and this is the third reply")
+        expect(reply.revisions.count).to eq(1)
+        expect(reply.revisions.first.modifications["raw"]).to eq([raw, reply.raw])
+        expect(reply.revisions.first.modifications["edit_reason"][1]).to eq(I18n.t(:removed_direct_reply_full_quotes))
+      end
+    end
+    it "does nothing when 'remove_full_quote' is disabled" do
+      SiteSetting.remove_full_quote = false
+      reply = Fabricate(:post, topic: topic, raw: raw)
-      expect(topic.posts).to eq([post, hidden, small_action, reply])
-      expect(reply.raw).to eq("and this is the third reply")
-      expect(reply.revisions.count).to eq(1)
-      expect(reply.revisions.first.modifications["raw"]).to eq([raw, reply.raw])
-      expect(reply.revisions.first.modifications["edit_reason"][1]).to eq(I18n.t(:removed_direct_reply_full_quotes))
+      expect(reply.raw).to eq(raw)
GitHub
