FEATURE: Allow admins to pre-populate user fields (PR #12361)
Admins can use bulk invites to pre-populate user fields. The imported CSV file must have a header with “email” column (first position) and names of the user fields (exact match).
Under the hood, the bulk invite will create staged users and populate the custom fields of those.
GitHub
We do this a lot. I wonder if it would make sense to add a helper? My feeling is code outside of user probably needn’t be messing with prefixes. For example:
user.set_user_field(user_field, value)
