FEATURE: allow removal of followup button (#31)
The followup button can be handy in many cases, but it can also create lots of broken windows where commits sit in limbo for many months or even years.
This allows opting out of this button by setting code_review_allow_manual_followup to false in site setting
Default behavior is not impacted
diff --git a/app/controllers/discourse_code_review/code_review_controller.rb b/app/controllers/discourse_code_review/code_review_controller.rb
index 5881589..ef35c8b 100644
--- a/app/controllers/discourse_code_review/code_review_controller.rb
+++ b/app/controllers/discourse_code_review/code_review_controller.rb
@@ -81,6 +81,10 @@ module DiscourseCodeReview
     def followup
+      if !SiteSetting.code_review_allow_manual_followup
+        raise Discourse::InvalidAccess
+      end
       topic = Topic.find_by(id: params[:topic_id])
       State::CommitApproval.followup(
diff --git a/assets/javascripts/discourse/initializers/init-code-review.js.es6 b/assets/javascripts/discourse/initializers/init-code-review.js.es6
index ba9feda..7e4bee5 100644
--- a/assets/javascripts/discourse/initializers/init-code-review.js.es6
+++ b/assets/javascripts/discourse/initializers/init-code-review.js.es6
@@ -68,7 +68,11 @@ function initialize(api) {
-  function allowFollowup(topic, siteSettings) {
+  function allowFollowupButton(topic, siteSettings) {
+    if (!siteSettings.code_review_allow_manual_followup) {
+      return false;
     const approvedTag = siteSettings.code_review_approved_tag;
     const pendingTag = siteSettings.code_review_pending_tag;
     const followupTag = siteSettings.code_review_followup_tag;
@@ -142,7 +146,7 @@ function initialize(api) {
     displayed() {
       return (
         this.get("currentUser.staff") &&
-        allowFollowup(this.topic, this.siteSettings)
+        allowFollowupButton(this.topic, this.siteSettings)
diff --git a/config/locales/server.en.yml b/config/locales/server.en.yml
index a6d4a16..cb7dcb7 100644
--- a/config/locales/server.en.yml
+++ b/config/locales/server.en.yml
@@ -5,6 +5,7 @@ en:
     code_review_sync_to_github: "REQUIRES: code_review_github_token, should comments here be sent to github?"
     code_review_catch_up_commits: "When a new repo is added create this number of topics for old commits"
     code_review_allow_private_clone: "REQUIRES: code_review_github_token, will clone the repos as the associated user, this safeguard is in place to disable cloning of private repos on public sites."
+    code_review_allow_manual_followup: "Allow follow up button on commits"
     code_review_pending_tag: "Tag to apply to pending commits"
     code_review_followup_tag: "Tag to apply to follow up commits"
     code_review_approved_tag: "Tag to apply to approved commits"
diff --git a/config/settings.yml b/config/settings.yml
index a0f9112..a5db236 100644
--- a/config/settings.yml
+++ b/config/settings.yml
@@ -4,6 +4,9 @@ plugins:
   code_review_sync_to_github: false
   code_review_catch_up_commits: 10
   code_review_allow_private_clone: false
+    client: true
+    default: true
     client: true
     default: "pending"
diff --git a/spec/requests/discourse_code_review/code_review_controller_spec.rb b/spec/requests/discourse_code_review/code_review_controller_spec.rb
index 165fa78..11422d8 100644
--- a/spec/requests/discourse_code_review/code_review_controller_spec.rb
+++ b/spec/requests/discourse_code_review/code_review_controller_spec.rb
@@ -275,6 +275,13 @@ describe DiscourseCodeReview::CodeReviewController do
         expect(commit.topic.tags.pluck(:name)).to include("hi", SiteSetting.code_review_followup_tag)
+      it 'gives invalid access when manual follow up is disabled' do
+        SiteSetting.code_review_allow_manual_followup = false
+        commit = create_post(raw: "this is a fake commit", tags: ["hi", SiteSetting.code_review_pending_tag])
+        post '/code-review/followup.json', params: { topic_id: commit.topic_id }
+        expect(response.status).to eq(403)
+      end
       it 'does nothing when following-up already followed-up posts' do
GitHub sha: 5893f9cf
This commit appears in #31 which was approved by tgxworld. It was merged by SamSaffron.
