FEATURE: Allow users to remove their vote (PR #14459)
They can use the remove vote button or select the same option again for single choice polls.
GitHub
Do we need to push it if it’s undefined?
Ditto ^^
Should probably use the DELETE verb and a different route on the server to handle the removal of a vote
Why couldn’t they remove their vote on multiple choices polls?
I think we still need this since we should be using a different route for the vote removal
This handles the case when a user clicks again on the option. I implemented this just for single choice polls because it is a bad user experience for multiple choice polls.
I see. Nice.
How does the button look like? Would it be better to make it red?
There is already a red button to close the poll.
This pull request has been mentioned on Discourse Meta. There might be relevant details there:
I’m personally not a huge fan of extending the DiscoursePoll::Poll.vote method to be able to remove vote because the original intend of the method is to cast a vote. A new method like DiscoursePoll::Poll.remove_vote would make it much clearer IMO.
This is not related to your change but I wished we had use a custom error class instead. This is rescuing all errors whether they are related to poll vote or not.
@nbianca I really like the refactor that you did here. Things are properly organised and alot easier to follow.
Why is vote called options? :thinking:
Love that you’ve made a method for each operations :clap:
I would have put the current_user as the 1st parameter but that’s nitpicking.
Since you’re not using post anywhere else, there’s no point in loading it using find_by. Maybe just use exists?
Why was this removed?
I am not sure exactly why, but this is the name in JavaScript too. It makes sense because a vote is nothing more than a set of selected poll options.
It was unused.
