FEATURE: better wizard privacy controls (#7391)
diff --git a/app/assets/javascripts/wizard/templates/components/wizard-field-radio.hbs b/app/assets/javascripts/wizard/templates/components/wizard-field-radio.hbs
index cb65052..8994de0 100644
--- a/app/assets/javascripts/wizard/templates/components/wizard-field-radio.hbs
+++ b/app/assets/javascripts/wizard/templates/components/wizard-field-radio.hbs
@@ -1,5 +1,5 @@
 {{#each field.choices as |c|}}
-  <div class="radio-field-choice">
+  <div class="radio-field-choice {{fieldClass}}">
     {{radio-button value=field.value
                    radioValue=c.id
                    label=c.label
diff --git a/app/assets/stylesheets/wizard.scss b/app/assets/stylesheets/wizard.scss
index 6496345..6d62aa4 100644
--- a/app/assets/stylesheets/wizard.scss
+++ b/app/assets/stylesheets/wizard.scss
@@ -73,6 +73,21 @@ body.wizard {
   font-weight: bold;
+.wizard-step-privacy {
+  label[for="privacy_options"] .field-description {
+    color: #444;
+    margin-bottom: 1em;
+  .field-privacy-options {
+    margin-bottom: 0.8em;
+    .radio-label {
+      font-weight: normal;
 .wizard-step-form {
   max-height: 500px;
diff --git a/config/locales/server.en.yml b/config/locales/server.en.yml
index cc4752b..239c724 100644
--- a/config/locales/server.en.yml
+++ b/config/locales/server.en.yml
@@ -4284,8 +4284,15 @@ en:
               restricted:
                 label: "Private"
                 description: "Only logged in users can access this community"
-          invite_only:
-            placeholder: "People must be explicitly invited. Public registration is disabled."
+          privacy_options:
+            description: "How do new users sign up for an account?"
+            choices:
+              open:
+                label: "Users can sign up on their own."
+              invite_only:
+                label: "Users can sign up on their own, but must be approved by staff."
+              must_approve:
+                label: "Users must be invited by trusted users or staff before they can sign up."
       contact:
         title: "Contact"
diff --git a/lib/wizard/builder.rb b/lib/wizard/builder.rb
index b0abb21..3e896ec 100644
--- a/lib/wizard/builder.rb
+++ b/lib/wizard/builder.rb
@@ -83,15 +83,25 @@ class Wizard
         privacy.add_choice('open', icon: 'unlock')
         privacy.add_choice('restricted', icon: 'lock')
-        invite_only = step.add_field(id: 'invite_only',
-                                     type: 'checkbox',
-                                     required: false,
-                                     placeholder: 'wizard.invites.add_user',
-                                     value: SiteSetting.invite_only?)
+        unless SiteSetting.invite_only? && SiteSetting.must_approve_users?
+          privacy_option_value = "open"
+          privacy_option_value = "invite_only" if SiteSetting.invite_only?
+          privacy_option_value = "must_approve" if SiteSetting.must_approve_users?
+          privacy_options = step.add_field(id: 'privacy_options',
+                                           type: 'radio',
+                                           required: true,
+                                           value: privacy_option_value)
+          privacy_options.add_choice('open')
+          privacy_options.add_choice('invite_only')
+          privacy_options.add_choice('must_approve')
+        end
         step.on_update do |updater|
           updater.update_setting(:login_required, updater.fields[:privacy] == 'restricted')
-          updater.update_setting(:invite_only, updater.fields[:invite_only])
+            updater.update_setting(:invite_only, updater.fields[:privacy_options] == "invite_only")
+            updater.update_setting(:must_approve_users, updater.fields[:privacy_options] == "must_approve")
+          end
diff --git a/spec/components/wizard/step_updater_spec.rb b/spec/components/wizard/step_updater_spec.rb
index a79f34d..f38190a 100644
--- a/spec/components/wizard/step_updater_spec.rb
+++ b/spec/components/wizard/step_updater_spec.rb
@@ -63,7 +63,7 @@ describe Wizard::StepUpdater do
   context "privacy settings" do
     it "updates to open correctly" do
-      updater = wizard.create_updater('privacy', privacy: 'open', invite_only: false)
+      updater = wizard.create_updater('privacy', privacy: 'open', privacy_options: 'open')
       updater.update
       expect(updater.success?).to eq(true)
       expect(SiteSetting.login_required?).to eq(false)
@@ -72,7 +72,7 @@ describe Wizard::StepUpdater do
     it "updates to private correctly" do
-      updater = wizard.create_updater('privacy', privacy: 'restricted', invite_only: true)
+      updater = wizard.create_updater('privacy', privacy: 'restricted', privacy_options: 'invite_only')
       updater.update
       expect(SiteSetting.login_required?).to eq(true)
diff --git a/spec/components/wizard/wizard_builder_spec.rb b/spec/components/wizard/wizard_builder_spec.rb
index a9c671e..b0846fb 100644
--- a/spec/components/wizard/wizard_builder_spec.rb
+++ b/spec/components/wizard/wizard_builder_spec.rb
@@ -119,16 +119,28 @@ describe Wizard::Builder do
     it 'should set the right default value for the fields' do
       SiteSetting.login_required = true
-      SiteSetting.invite_only = false
+      SiteSetting.invite_only = true
       fields = privacy_step.fields
       login_required_field = fields.first
-      invite_only_field = fields.last
+      privacy_options_field = fields.last
+      expect(fields.length).to eq(2)
       expect(login_required_field.id).to eq('privacy')
       expect(login_required_field.value).to eq("restricted")
-      expect(invite_only_field.id).to eq('invite_only')
-      expect(invite_only_field.value).to eq(false)
+      expect(privacy_options_field.id).to eq('privacy_options')
+      expect(privacy_options_field.value).to eq("invite_only")
+    end
+    it 'should not show privacy_options field on special case' do
+      SiteSetting.must_approve_users = true
+      fields = privacy_step.fields
+      login_required_field = fields.first
+      expect(fields.length).to eq(1)
+      expect(login_required_field.id).to eq('privacy')
GitHub sha: a63ef4cf
